//变量定义
__IO uint16_t ADCConvertedValue[10];
//ADC 外设的数据寄存器
#define ADC1_DR_Address ((uint32_t)0x4001244C)
//ADC_DR(ADC规则数据寄存器),偏移量=0x4c ADC1(0x40012400-0x400127ff)
//ADC1_GPIO配置
void ADC1_GPIO_Configuration(void)
/* Configure PC.01 (ADC Channel11) as analog input -------------------------*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //adc模式必须是模拟输入
GPIO_Init(GPIOC, &GPIO_InitStructure);//执行上面的操作
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_Init(GPIOA, &GPIO_InitStructure);//执行上面的操作
//注意,内部温度对应 16通道,无引脚,只需开启adc时钟即可。
//内部参考电压,对应17 通道。无引脚。只需开启时钟
//外设ADC,DMA时钟开启
void ADC1_DMA_RCC_Configuration(void)
/* Enable peripheral clocks ------------------------------------------------*/
/* Enable DMA1 clock */
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
/* Enable ADC1 and GPIOC clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOC| RCC_APB2Periph_GPIOA, ENABLE);
//ADC1 DMA 配置
void ADC1_DMA_Init(void)
ADC_InitTypeDef ADC_InitStructure;
DMA_InitTypeDef DMA_InitStructure;
/* DMA1 channel1 configuration ----------------------------------------------*/
DMA_DeInit(DMA1_Channel1); //选择DMA的通道1
//设定从ADC外设的数据寄存器(ADC1_DR_Address)转移到内存(ADCConcertedValue)
//每次传输大小16位,使用DMA循环传输模式
DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ADCConvertedValue;//数据缓冲区的地址
//外设为数据源
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
//数据缓冲区,大小2半字
DMA_InitStructure.DMA_BufferSize = 10;
// 外设地址固定
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
//内存地址增加,多组adc时,使能,数据传输时,内存增加
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
//半字
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
//DMA循环传输
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
//优先级高
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
//执行
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
/* Enable DMA1 channel1 */
DMA_Cmd(DMA1_Channel1, ENABLE);
/* ADC1 configuration ------------------------------------------------------*/
//ADC独立模式 相对于双重模式
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
//扫描模式用于多通道采集
ADC_InitStructure.ADC_ScanConvMode = ENABLE;
//开启连续转换模式 当转换完本组(可能是一个)继续重新开始执行
//相对于单次模式:转换一次后就结束
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
//不使用外部触发转换
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
//采集数据右对齐
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
//转换组的通道数目
ADC_InitStructure.ADC_NbrOfChannel =10;
//执行
ADC_Init(ADC1, &ADC_InitStructure);
//配置ADC时钟,为PCLK2的8分频,即9Hz
RCC_ADCCLKConfig(RCC_PCLK2_Div8);
/* ADC1 regular channel11 configuration */
//配置ADC1的通道11为55.5个采样周期
//默认组,adc1 ,通道11,排序为1,55.5周期
//ADC1,ch17,序号1,55.5.。。
ADC_RegularChannelConfig(ADC1, ADC_Channel_17,1, ADC_SampleTime_239Cycles5);
//ADC1,ch16,序号1,55.5.。。
ADC_RegularChannelConfig(ADC1, ADC_Channel_16,2, ADC_SampleTime_239Cycles5);
//ADC1,ch4,序号1,55.5.。。
ADC_RegularChannelConfig(ADC1, ADC_Channel_4,3, ADC_SampleTime_239Cycles5);
//ADC1,ch5,序号1,55.5.。。
ADC_RegularChannelConfig(ADC1, ADC_Channel_5,4, ADC_SampleTime_239Cycles5);
//ADC1,ch6,序号1,55.5.。。
ADC_RegularChannelConfig(ADC1, ADC_Channel_6,5, ADC_SampleTime_239Cycles5);
//ADC1,ch7,序号1,55.5.。。
ADC_RegularChannelConfig(ADC1, ADC_Channel_7,6, ADC_SampleTime_239Cycles5);
//ADC1,ch10,序号1,55.5.。。
ADC_RegularChannelConfig(ADC1, ADC_Channel_10,7, ADC_SampleTime_239Cycles5);
//ADC1,ch11,序号1,55.5.。。
ADC_RegularChannelConfig(ADC1, ADC_Channel_11,8, ADC_SampleTime_239Cycles5);
//ADC1,ch12,序号1,55.5.。。
ADC_RegularChannelConfig(ADC1, ADC_Channel_12,9, ADC_SampleTime_239Cycles5);
//ADC1,ch13,序号1,55.5.。。
ADC_RegularChannelConfig(ADC1, ADC_Channel_13,10, ADC_SampleTime_239Cycles5);
//----------------------使能温度传感器----------------------------
ADC_TempSensorVrefintCmd(ENABLE);
/* Enable ADC1 DMA */
//使能ADC_DMA
ADC_DMACmd(ADC1, ENABLE);
/* Enable ADC1 */
//使能ADC
ADC_Cmd(ADC1, ENABLE);
/* Enable ADC1 reset calibration register */
//使能ADC1的复位校准寄存器
ADC_ResetCalibration(ADC1);
/* Check the end of ADC1 reset calibration register */
//等待校准完成
while(ADC_GetResetCalibrationStatus(ADC1));
/* Start ADC1 calibration */
//使能ADC1的开始校准寄存器
ADC_StartCalibration(ADC1);
/* Check the end of ADC1 calibration */
//等待完成
while(ADC_GetCalibrationStatus(ADC1));
/* Start ADC1 Software Conversion */
//使用软件触发,由于没有采用外部触发
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
关键字:stm32 ADC DMA模式『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
