STARTUP.A51原始文件:
1 $NOMOD51;Ax51宏汇编器控制命令,禁止预定义的8051。使编译器不使能预定义的;8051符号,避免产生重复定义的错误。
2 ;------------------------------------------------------------------------------
3 ; This file is part of the C51 Compiler package
4 ; Copyright (c) 1988-2005 Keil Elektronik GmbH and Keil Software, Inc.
5 ; Version 8.01
6 ;
7 ; *** <<< Use Configuration Wizard in Context Menu >>> ***
8 ;------------------------------------------------------------------------------
9 ; STARTUP.A51: This code is executed after processor reset.
10 ;
11 ; To translate this file use A51 with the following invocation:
12 ;
13 ; A51 STARTUP.A51
14 ;
15 ; To link the modified STARTUP.OBJ file to your application use the following
16 ; Lx51 invocation:
17 ;
18 ; Lx51 your object file list, STARTUP.OBJ controls
19 ;
20 ;------------------------------------------------------------------------------
21 ;
22 ; User-defined
23 ;
24 ; With the following EQU statements the initialization of memory
25 ; at processor reset can be defined:
26 ;
27 ;
28 ; Note: The absolute start-address of IDATA memory is always 0
29 ; The IDATA space overlaps physically the DATA and BIT areas.
30 IDATALEN EQU 80H
31 ;
32 ;
33 ; The absolute start address of XDATA memory
34 XDATASTART EQU 0
35 ;
36 ;
37 ; The length of XDATA memory in bytes.
38 XDATALEN EQU 0
39 ;
40 ;
41 ; The absolute start address of PDATA memory
42 PDATASTART EQU 0H
43 ;
44 ;
45 ; The length of PDATA memory in bytes.
46 PDATALEN EQU 0H
47 ;
48 ;
49 ;------------------------------------------------------------------------------
50 ;
51 ;
52 ;
53 ; The following EQU statements define the stack pointer for reentrant
54 ; functions and initialized it:
55 ;
56 ;
57 ; IBPSTACK: Enable SMALL model reentrant stack
58 ; Stack space for reentrant functions in the SMALL model.
59 IBPSTACK EQU 0 ; set to 1 if small reentrant is used.
60 ;
61 ; Set the top of the stack to the highest location.
62 IBPSTACKTOP EQU 0xFF +1 ; default 0FFH+1
63 ;
64 ;
65 ;
66 ; XBPSTACK: Enable LARGE model reentrant stack
67 ; Stack space for reentrant functions in the LARGE model.
68 XBPSTACK EQU 0 ; set to 1 if large reentrant is used.
69 ;
70 ; Set the top of the stack to the highest location.
71 XBPSTACKTOP EQU 0xFFFF +1 ; default 0FFFFH+1
72 ;
73 ;
74 ;
75 ; PBPSTACK: Enable COMPACT model reentrant stack
76 ; Stack space for reentrant functions in the COMPACT model.
77 PBPSTACK EQU 0 ; set to 1 if compact reentrant is used.
78 ;
79 ;
80 ; Set the top of the stack to the highest location.
81 PBPSTACKTOP EQU 0xFF +1 ; default 0FFH+1
82 ;
83 ;
84 ;------------------------------------------------------------------------------
85 ;
86 ; Memory Page for Using the Compact Model with 64 KByte xdata RAM
87 ;
88 ;
89 ; Define the XDATA page used for PDATA variables.
90 ; PPAGE must conform with the PPAGE set in the linker invocation.
91 ;
92 ; Enable pdata memory page initalization
93 PPAGEENABLE EQU 0 ; set to 1 if pdata object are used.
94 ;
95 ;
96 ; uppermost 256-byte address of the page used for PDATA variables.
97 PPAGE EQU 0
98 ;
99 ;
100 ; most 8051 variants use P2 as uppermost address byte
101 PPAGE_SFR DATA 0A0H
102 ;
103 ;
104 ;------------------------------------------------------------------------------
105
106 ; Standard SFR Symbols
107 ACC DATA 0E0H
108 B DATA 0F0H
109 SP DATA 81H
110 DPL DATA 82H
111 DPH DATA 83H
112
113 NAME ?C_STARTUP
114
115
116 ?C_C51STARTUP SEGMENT CODE
117 ?STACK SEGMENT IDATA
118
119 RSEG ?STACK
120 DS 1
121
122 EXTRN CODE (?C_START)
123 PUBLIC ?C_STARTUP
124
125 CSEG AT 0
126
