单片机源程序如下:
//数码管位 高位-----低位
//四个按键控制步进电机:正转,反转,加1,减1
//上电时电机启动,数码管上显示速度最小档1,加减档位均能通过数码管显示出来,电机采用单双八拍方式
//电机转速一共10档,通过按键调节转速
//电机正转时最高位数码管显示0,反转时显示1
#include
#define uchar unsigned char
#define uint unsigned int
#define led P0//数码管段选
#define haha P2
sbit s1 = P1^0;
sbit s2 = P1^1;
sbit s3 = P3^0;
sbit s4 = P3^1;
sbit s5 = P3^2;//按键定义,s1正转,s2反转,s3加1,s4减1
sbit wei3 = P2^3;sbit wei2 = P2^2;sbit wei1 = P2^1;sbit wei0 = P2^0;//数码管位选定义
sbit a = P2^7;sbit b = P2^6;sbit c = P2^5;sbit d = P2^4;//脉冲信号输入端定义
uchar code tab[11]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};//共阳数码管驱动信号0---9,不显示
uchar code time_counter[10][2]={{0xda,0x1c},{0xde,0xe4},{0xe1,0xec},{0xe5,0xd4},{0xe9,0xbc}, //9.7 ----1ms
{0xed,0xa4},{0xf1,0x8c},{0xf5,0x74},{0xf9,0x5c},{0xfc,0x18}};
uchar code qudong[8]={0x80,0xc0,0x40,0x60,0x20,0x30,0x10,0x90};
uchar num1 = 0;//控制取励磁信号变量
uchar num2 = 8;
char k=0;//加减档位控制,1为最小档
char pause=1;//暂停时保存之前的转速,开机默认1
bit flag1 = 0;//初始正转,正反转标志
uchar buf[4]={0,10,0,0};//数码管显示缓存,正转,不显示,不显示,显示1档位,高----低
//================================定时器0/1初始化函数================================
void T0_T1_init()
TMOD = 0x11;//定时器0/1均工作于方式1,16位计时方式
TH1 = time_counter[k-1][0];
TL1 = time_counter[k-1][1];//定时器1,定时10ms用于步进电机转速控制
TR1 = 0;
ET1= 1;//开定时器中断
EA = 1;//开总中断
//================================ms级延时函数=======================================
void delay1m(uint x)
uint i,j;
for(i=0;i
for(j=0;j<120;j++); //数120 次,约1 ms
void display()
wei3=1;wei2=1;wei1=1;wei0=0;led = tab[buf[3]];delay1m(1);led=0xff;
wei3=1;wei2=1;wei1=0;wei0=1;led = tab[buf[2]];delay1m(1);led=0xff;
wei3=1;wei2=0;wei1=1;wei0=1;led = tab[buf[1]];delay1m(1);led=0xff;
wei3=0;wei2=1;wei1=1;wei0=1;led = tab[buf[0]];delay1m(1);led=0xff;
//================================主函数=============================================
void main()
T0_T1_init();
buf[1] = 10;//不显示
while(1)
display();
if(s1 == 0)
delay1m(3);
if(s1 == 0)
flag1 = 0;//正转
buf[0] = 0;//最高位显示0
// haha = 0x00;//停止
while(!s1) display();
if(s2 == 0 )
delay1m(3);
if(s2 == 0)
flag1 = 1;//反转
buf[0] = 1;//最高位显示1
// haha = 0x00;//停止
while(!s2) display();
if(s3 == 0) //速度加1档
delay1m(3);
if(s3 == 0)
k++;
TR1=1;
if(k > 10 )
k = 1;
buf[2]= k/10;
buf[3]= k%10;
while(!s3) display();
if(s4 == 0) //速度减1档
delay1m(3);
if(s4 == 0)
k--;
TR1=1;
if(k <= 0)
k = 10;
buf[2]= k/10;
buf[3]= k%10;
while(!s4) display();
if(s5==0)
delay1m(3);
if(s5==0)
if(TR1==1)
pause=k;
