51循迹智能小车仿真电路及程序
仿真原理图如下
单片机源程序如下:
#include
#define uchar unsigned char
#define uint unsigned int
uchar temp,signal,tt1,t0,t1,t2,t3,t4,t5,t6;
void delay_1ms(uint d)
uint i;
while(d--)
for(i=0;i<75;i++);
void motor_run() //电机起动
P1=0x35;
delay_1ms(200);
P1=0x53;
delay_1ms(10);
/* ENA=1;
OUT1=0;
OUT2=1;
delay_1ms(800);
OUT2=0;
delay_1ms(200);
ENB=1;
OUT4=0;
OUT3=1;
delay_1ms(800);
OUT3=0;
delay_1ms(200);
void motor_left() //左进
P1=0x30;
delay_1ms(200);
P1=0x00;
delay_1ms(20);
void motor_right() //右进
P1=0x05;
delay_1ms(200);
P1=0x00;
delay_1ms(20);
void motor_big_right() //粗右进
P1=0x55;
delay_1ms(200);
P1=0x00;
delay_1ms(20);
void motor_big_left()
P1=0x33;
delay_1ms(200);
P1=0x00;
delay_1ms(20);
void motor_stop() //电机停止
P1=0x00;
void motor_back()
P1=0x53;
void main()
t0=0;
t1=0;
t2=0;
t3=0;
t4=0;
t5=0;
t6=0;
tt1=0;
EA=1;
ET1=1;
TR1=1;
TMOD=0x01;
TH1=-(1000/256);
TL1=-(1000%256);
while(1)
temp=P2;
signal=temp&0xff; //得到红外反向信号
switch(signal)
case 0xff: //无偏差
motor_run();
t0++;
if(t0==10)
t0=0;
motor_left();
motor_right();
t1=t2=t3=t4=t5=t6=0;
break;
case 0xfd: //1轮右偏
motor_big_left();
t1++;
if(t1==4)
t1=0;
motor_left();
t0=t2=t3=t4=t5=t6=0;
break;
case 0xef: //4轮左偏
motor_big_right();
t2++;
if(t2==4)
t2=0;
motor_right();
t0=t1=t3=t4=t5=t6=0;
break;
case 0xfb: //2轮右偏出轨
case 0xf9: //1、2轮右偏
motor_big_left();
t3++;
if(t3==4)
t3=0;
motor_left();
t0=t1=t2=t4=t5=t6=0;
// delay_1ms(10);
break;
case 0xdf: //5左偏出轨
case 0xcf: //4、5轮左偏
motor_big_right();
t4++;
