好记心不如烂笔头,为方便以后查看代码及代码重复利用,这里贴出S3C2440 UART驱动代码。使用友善MINI2440开发板,开发环境为RealView MDK 4.22。需要注意的是,本代码中,对GPIO的初始化放在了s3c2440.s中完成,采用keil自带的html方式进行配置。
该源码结构简单明了,原始工程下载地址:点击打开链接
UART控制器初始化:
void Uart_Init(void)
#define rULCON0 (*(volatile unsigned int*)0x50000000)
#define rUCON0 (*(volatile unsigned int*)0x50000004)
#define rUBRDIV0 (*(volatile unsigned int*)0x50000028)
#define PCLK 50000000
#define BUADRATE 115200
rULCON0 = 0x03; //No parity, One stop bit, 8-bits data
rUCON0 = 0x05; //Tx Enable, Rx Enable, PCLK as source clock
rUBRDIV0 = (int)(PCLK / (BUADRATE * 16)) - 1; //115200bps
字符发送函数:
void Uart_Putc(unsigned char c)
#define rUTRSTAT0 (*(volatile unsigned int*)0x50000010)
#define rUTXH0 (*(volatile unsigned int*)0x50000020)
#define BUFFER_EMPTY (1 <
while(!(rUTRSTAT0 & BUFFER_EMPTY));
rUTXH0 = c;
字符接收函数:
unsigned char Uart_Getc(void)
#define rURXH0 (*(volatile unsigned int*)0x50000024)
#define BUFFER_READY (1 <
while(!(rUTRSTAT0 & BUFFER_READY));
return rURXH0;
为了使用printf库函数,需要进行如下重映射:
struct __FILE
int handle;
/* Whatever you require here. If the only file you are using is */
/* standard output using printf() for debugging, no file handling */
/* is required. */
/* FILE is typedef'd in stdio.h. */
FILE __stdout;
int fputc(int ch, FILE *f)
Uart_Putc(ch);
return ch;
int ferror(FILE *f) {
/* Your implementation of ferror */
return EOF;
测试代码:
int main(void)
unsigned char ch;
//clock_init();
Uart_Init();
printf("%s, %d", __FILE__, __LINE__);
while(1)
ch = Uart_Getc();
Uart_Putc(ch);
