学习这里首先要了解一下SD卡基本资料:
https://prod-1251541497.cos.ap-guangzhou.myqcloud.com/zixun_pc/zixunimg/img2/news-uploadfile-2018-1226-20181226041927610.jpghttps://prod-1251541497.cos.ap-guangzhou.myqcloud.com/zixun_pc/zixunimg/img2/news-uploadfile-2018-1226-20181226041927610.jpg
SD卡的协议部分太多,也比较复杂,建议资料:《Simplified_Physical_Layer_Spec.pdf》其主要复杂在繁多的命令,一共有64个命令,各个命令代表什么可查资料。
关于这里大部分都是熟悉函数然后直接调用库就行,但还是需要每个函数都去读一下的,后面会有具体函数的使用实例,到时候再补充。
我们代码中一般用到的是ARM官方给的SD卡的库,但是库中存在问题,SD_Error SD_ReadBlock()缺少代码:(有标注,可直接替换)
SD_Error SD_ReadBlock(uint8_t *readbuff, uint32_t ReadAddr, uint16_t BlockSize)
SD_Error errorstatus = SD_OK;
#if defined (SD_POLLING_MODE)
uint32_t count = 0, *tempbuff = (uint32_t *)readbuff;
#endif
TransferError = SD_OK;
TransferEnd = 0; //传输结束标置位,在中断服务置1
StopCondition = 0; //怎么用的?
SDIO->DCTRL = 0x0;
if (CardType == SDIO_HIGH_CAPACITY_SD_CARD)
BlockSize = 512;
ReadAddr /= 512;
/*******************add,没有这一段容易卡死在DMA检测中*************************************/
/* Set Block Size for Card,cmd16,
* 若是sdsc卡,可以用来设置块大小,
* 若是sdhc卡,块大小为512字节,不受cmd16影响
SDIO_CmdInitStructure.SDIO_Argument = (uint32_t) BlockSize;
SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_SET_BLOCKLEN;
SDIO_CmdInitStructure.SDIO_Response = SDIO_Response_Short; //r1
SDIO_CmdInitStructure.SDIO_Wait = SDIO_Wait_No;
SDIO_CmdInitStructure.SDIO_CPSM = SDIO_CPSM_Enable;
SDIO_SendCommand(&SDIO_CmdInitStructure);
errorstatus = CmdResp1Error(SD_CMD_SET_BLOCKLEN);
if (SD_OK != errorstatus)
return(errorstatus);
SDIO_DataInitStructure.SDIO_DataTimeOut = SD_DATATIMEOUT;
SDIO_DataInitStructure.SDIO_DataLength = BlockSize;
SDIO_DataInitStructure.SDIO_DataBlockSize = (uint32_t) 9 << 4;
SDIO_DataInitStructure.SDIO_TransferDir = SDIO_TransferDir_ToSDIO;
SDIO_DataInitStructure.SDIO_TransferMode = SDIO_TransferMode_Block;
SDIO_DataInitStructure.SDIO_DPSM = SDIO_DPSM_Enable;
SDIO_DataConfig(&SDIO_DataInitStructure);
/*!< Send CMD17 READ_SINGLE_BLOCK */
SDIO_CmdInitStructure.SDIO_Argument = (uint32_t)ReadAddr;
SDIO_CmdInitStructure.SDIO_CmdIndex = SD_CMD_READ_SINGLE_BLOCK;
errorstatus = CmdResp1Error(SD_CMD_READ_SINGLE_BLOCK);
if (errorstatus != SD_OK)
/*!< In case of single block transfer, no need of stop transfer at all.*/
/*!< Polling mode */
while (!(SDIO->STA &(SDIO_FLAG_RXOVERR | SDIO_FLAG_DCRCFAIL | SDIO_FLAG_DTIMEOUT | SDIO_FLAG_DBCKEND | SDIO_FLAG_STBITERR)))
if (SDIO_GetFlagStatus(SDIO_FLAG_RXFIFOHF) != RESET)
for (count = 0; count < 8; count++)
*(tempbuff + count) = SDIO_ReadData();
tempbuff += 8;
if (SDIO_GetFlagStatus(SDIO_FLAG_DTIMEOUT) != RESET)
SDIO_ClearFlag(SDIO_FLAG_DTIMEOUT);
errorstatus = SD_DATA_TIMEOUT;
else if (SDIO_GetFlagStatus(SDIO_FLAG_DCRCFAIL) != RESET)
SDIO_ClearFlag(SDIO_FLAG_DCRCFAIL);
errorstatus = SD_DATA_CRC_FAIL;
else if (SDIO_GetFlagStatus(SDIO_FLAG_RXOVERR) != RESET)
SDIO_ClearFlag(SDIO_FLAG_RXOVERR);
errorstatus = SD_RX_OVERRUN;
else if (SDIO_GetFlagStatus(SDIO_FLAG_STBITERR) != RESET)
SDIO_ClearFlag(SDIO_FLAG_STBITERR);
errorstatus = SD_START_BIT_ERR;
while (SDIO_GetFlagStatus(SDIO_FLAG_RXDAVL) != RESET)
*tempbuff = SDIO_ReadData();
tempbuff++;
/*!< Clear all the static flags */
SDIO_ClearFlag(SDIO_STATIC_FLAGS);
#elif defined (SD_DMA_MODE)
SDIO_ITConfig(SDIO_IT_DATAEND, ENABLE);
SDIO_DMACmd(ENABLE);
SD_DMA_RxConfig((uint32_t *)readbuff, BlockSize);
#endif
关键字:STM32 SDIO SD卡读取『本文转载自网络,版权归原作者所有,如有侵权请联系删除』
