单片机源程序如下:
/****************************************Copyright (c)****************************************************
**--------------File Info---------------------------------------------------------------------------------
** File name: main.c
** Last modified Date: 2009-05-12
** Last Version: V1.01
** Descriptions: The main() function example template
** Created by: Chengmingji
** Created date: 2009-07-24
** Version: V1.00
** Descriptions: 添加用户应用程序
** Modified by: Liangbaoqiong
** Modified date: 2009-07-27
** Version: V1.01
** Descriptions: 编写CAN例程
** Rechecked by: Zhang bin1
#include "LPC17xx.h" /* LPC17xx外设寄存器 */
#include "LPC1700CAN.h"
** Function name: SysDelay
** Descriptions: 较为准确的软件延时函数
** Input parameters: ulCount: 输入延时值,如该值为主频值,则延时时间为3秒
** output parameters: 无
** Returned value: 无
__asm void SysDelay (uint32_t ulCount)
subs r0, #1;
bne SysDelay;
bx lr;
extern uint32_t SystemFrequency;
** Function name: main
** Descriptions: 测试时短接JP15,逻辑分析仪分别与COM8中CANH和CANL相接,然后打开ZLGCANTest调试软件
** 设置波特率为1000kbps,启动观察接收情况
** input parameters: 无
int main (void)
unsigned char ucData11[]={0x11,0x22,0x33,0x44,0x55,0x66,0x77,0x88};
SystemInit(); /* 系统初始化 */
CAN_Init(0,BPS_10K); /* 初始化CAN1 通道 1M波特率 */
* 写报文信息(报文数据长度、是否标准帧、ID、发送数据所在的数组)
while(!writedetail(8,1, 0x08888888,ucData11));
while (1) {
CANSend(0, 2);
SysDelay(SystemFrequency / 6); /* 延时3/6 s = 500ms */
End Of File
