芯片为STM32F412VETx,使用的是高级定时器TIM1的PWM互补PWM输出,看一下STM32CubeMX配置,
再看时钟的配置,TIM1用的是APB2的时钟,。
再看引脚的配置
产生的PWM频率为:Fpwm = 96MHz / ((95+1)(9999+1)) =100Hz,占空比为50%
然后生成代码,看下代码中的FMX_TIM1_Init函数初始化
/* TIM1 init function */
static void FMX_TIM1_Init(void)
TIM_ClockConfigTypeDef sClockSourceConfig;
TIM_MasterConfigTypeDef sMasterConfig;
TIM_OC_InitTypeDef sConfigOC;
TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig;
htim1.Instance = TIM1;
htim1.Init.Prescaler = 95;
htim1.Init.CounterMode = TIM_COUNTERMODE_UP;
htim1.Init.Period = 9999;
htim1.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim1.Init.RepetitionCounter = 0;
if (HAL_TIM_Base_Init(&htim1) != HAL_OK) //使能TIM1时钟
_Error_Handler(__FILE__, __LINE__);
sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
if (HAL_TIM_ConfigClockSource(&htim1, &sClockSourceConfig) != HAL_OK)
if (HAL_TIM_PWM_Init(&htim1) != HAL_OK)
sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
if (HAL_TIMEx_MasterConfigSynchronization(&htim1, &sMasterConfig) != HAL_OK)
sConfigOC.OCMode = TIM_OCMODE_PWM1;
sConfigOC.Pulse = 5000;
sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH;
sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET;
sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
if (HAL_TIM_PWM_ConfigChannel(&htim1, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_DISABLE;
sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_DISABLE;
sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF;
sBreakDeadTimeConfig.DeadTime = 0;
sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE;
sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH;
sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE;
if (HAL_TIMEx_ConfigBreakDeadTime(&htim1, &sBreakDeadTimeConfig) != HAL_OK)
HAL_TIM_MspPostInit(&htim1); //引脚配置
好了到此TIM1的PWM互补已经配置完成,接下来就是要是要使能PWM输出了,接下在再main函数中使能输出就OK了。
HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_1); //starts PWM on CH1 pin
HAL_TIMEx_PWMN_Start(&htim1, TIM_CHANNEL_1); //starts PWM on CH1N pin
最好用示波器看下效果图
