利用两个定时器 来实现 3位数码管 同时显示计时器, 即从0- 999范围的计时
#include
//共阴极数码管编码范围
unsigned char code table[10]={0x3f,0x6,0x5b,0x4f,0x66,0x6d,0x7d,0x7,0x7f,0xef };
unsigned char first=0;
unsigned char second=0;
unsigned char third=0;
unsigned int number=0;
unsigned char t=0;
void Delay()
unsigned char j;
unsigned char i;
for(i=10; i>0; i--)
for(j=110; j>0; j--);
void main()
TMOD=0x11; //设置两个定时器T0,T1的工作方式: 使用16位寄存器的方式1
EA=1; //打开 全局中断
ET0=1; // 打开定时器T0的中断
ET1=1;
TR0=1; // 启动定时器T0
TR1=1;
TH0=(65536-50000)%256;
TL0=(65536-50000)%256;
TH1=(65536-50000)%256;
TL1=(65536-50000)%256;
while(1)
if(t==20)
t=0;
number++;
first=number/100;
second=(number-first*100)/10;
third=(number-first*100)%10;
void TimerLED0() interrupt 1 using 1
t++;
void TimerLED1() interrupt 3 using 2
TH1=(65536-10000)%256;
TL1=(65536-10000)%256;
P2=0xfe;
P0=table[first];
Delay();
P2=0xfd;
P0=table[second];
Delay();
P2=0xfb;
P0=table[third];
Delay();
