Engine Management Gasoline
The sophistication of today’s modern engine management systems are driven by strict governmental regulation mandating increased fuel economy and engine performance while lowering harmful emissions. This has driven the industry need to develop improvements to gasoline engine CONTROL systems, such as electronic throttle control, variable valve timing, electronic stability, and REMOTE starting, to name a few. ST, with a strong portfolio of ADVANCED TECHNOLOGIES (BCD for combining PRECISION ANALOG, power, DIGITAL and non-volatile MEMORY functions; VIPower for driving high current loads; Embedded FLASH 8/16/32-bit Microcontrollers for real-time control) coupled with extensive STANDARD product offering, is ready to meet the changing market demands.. A sampling of ST PRODUCTS that are applicable to Gasoline Engine Management Systems can be found in the following block diagram
1 VOLTAGE REGULATOR
L4925
2 Bus Transceiver
Data INTERFACE - Bus Transceivers [1]
L9616
3 Bus Transceiver
Data Interface - Bus Transceivers [1]
L9637
4 Control Unit
ST10F280
5 Memory
(1) Serial EEPROM, I2C Bus, M24 [4]
M24C04-W
M24C16-W
M24C32-W
(2) Serial EEPROM, I2C Bus, M24 [14]
M24128-BR
M24128-BW
M24256-BW
(3) Industry Standard, 5V, M29F [10]
M29F002BB
M29F002BT
M29F010B
(4) Industry Standard, 3V, M29W [1]
M29W010B
(5) Industry Standard, 5V, M29F [3]
M29F200BB
M29F400BB
M29F400BT
(6) Serial EEPROM, SPI Bus, M95 [5]
M95040
M95040-W
M95160
(7) Serial EEPROM, SPI Bus, M95 [7]
M95080
M95080-W
M95128-R
(8) Industry Standard, 3V, M29W [14]
M29W008EB
M29W040B
M29W160EB
(9) Automotive, Burst Mode, M58B [1]
M58BW016D
(10) Automotive, Burst Mode, M58B [1]
M58BW032
6 Actuator Driver
Low Side [1]
L9362
Low Side [1]
L9651
(1) Ignition Controllers and Drivers [2]
VB325
VB326
(2) 600V [7]
STGB10NB37LZ
STGB10NB40LZ
STGB20NB32LZ
(3) 600V [13]
STGB10NB60S
STGB10NC60HD
STGB10NC60K
8 Control Unit
(1) ST7 - 8-bit Microcontrollers [45]
ST72321AR6
ST72321AR7
ST72321AR9
(2) ST7 - 8-bit Microcontrollers [13]
ST72521AR6
ST72521AR9
ST72521M9
