Mechatronic Throttle Drive (1)
The throttle by wire concept is just one more way to enhance the engine CONTROL algorithm. With the engine control MODULE completely in charge of EVERYTHING from air fuel mixture to spark advance, electronically controlling the throttle plate only makes sense. ST’s solutions range from sophisticated brushless control configurations to efficient monolithic designs. ST has the answer to your electronic throttle needs.
1 VOLTAGE REGULATOR
(1) Low-Drop [2]
L4979
L4989
(2) Very Low-Drop [1]
L4925
2 Bus Transceiver
L9616
3 Bus Transceiver
L9637
4 MEMORY
(1) Serial EEPROM, I2C Bus, M24 [4]
M24C04-W
M24C16-W
M24C32-W
(2) Serial EEPROM, I2C Bus, M24 [14]
M24128-BR
M24128-BW
M24256-BW
(3) Serial Flash for Code Storage, M25P [9]
M25P05-A
M25P10-A
M25P128
(4) Serial EEPROM, SPI Bus, M95 [5]
M95040
M95040-W
M95160
(5) Serial EEPROM, SPI Bus, M95 [4]
M95080
M95080-W
M95160-W
