MICROCHIP 公司的PIC18F2585/2680/4585/4680是 28/40/44引脚的增强型闪存微控制器,具有ECAN™和nanoWatt技术以及10位ADC,适合许多高性能和对功耗敏感的应用。本文介绍了PIC18F 2680和PIC18F 4680在汽车轮胎监测系统(TPMS)的应用。首先介绍了PIC18F 2680和PIC18F 4680的主要性能和方框图,接着介绍了APGRD003 汽车轮胎监测系统(TPMS)的主要电路。
APGRD003 Tire Pressure Measurement SYSTEM
PIC18F2585/2680/4585/4680 28/40/44-Pin Enhanced Flash Microcontrollers with
ECAN TECHNOLOGY, 10-Bit A/D and nanoWatt Technology
Power Managed Modes:
Run: CPU on, peripherals on
Idle: CPU off, peripherals on
Sleep: CPU off, peripherals off
Idle mode currents down to 5.8 A typical
Sleep mode currents down to 0.1 A typical
Timer1 Oscillator: 1.1 A, 32 kHz, 2V
Watchdog Timer: 2.1 A
Two-Speed Oscillator Start-up
Flexible Oscillator Structure:
Four CRYSTAL modes, up to 40 MHz
4x Phase Lock Loop (PLL) – available for crystal and internal oscillators
Two External RC modes, up to 4 MHz
Two External Clock modes, up to 40 MHz
Internal oscillator block:
8 user selectable frequencies, from 31 kHz to 8 MHz
Provides a complete range of clock speeds, from 31 kHz to 32 MHz when used with PLL
User tunable to compensate for frequency drift
Secondary oscillator using Timer1 @ 32 kHz
Fail-Safe Clock MONITOR
Allows for safe shutdown if peripheral clock stops
Special Microcontroller Features:
C compiler optimized architecture with optional extended instruction set
100,000 erase/write cycle Enhanced Flash PROGRAM MEMORY typical
1,000,000 erase/write cycle Data EEPROM memory typical
Flash/Data EEPROM Retention: > 40 years
Self-programmable under SOFTWARE control
Priority levels for interrupts
8 x 8 SINGLE Cycle HARDWARE Multiplier
Extended Watchdog Timer (WDT):
Programmable period from 41 ms to 131s
Single-Supply 5V In-Circuit Serial PROGRAMMING™ (ICSP™) via two pins
In-Circuit Debug (ICD) via two pins
Wide operating VOLTAGE range: 2.0V to 5.5V
Peripheral Highlights:
High current sink/source 25 mA/25 mA
Three external interrupts
One Capture/Compare/PWM (CCP1) MODULE
Enhanced Capture/Compare/PWM (ECCP1) module (40/44-pin DEVICES only):
One, two or four PWM outputs
Selectable polarity
Programmable dead time
Auto-Shutdown and Auto-Restart
MASTER Synchronous Serial Port (MSSP) module supporting 3-wire SPI (all 4 modes) and I2C™ Master and Slave modes
Enhanced Addressable USART module:
Supports RS-485, RS-232 and LIN 1.3
RS-232 operation using internal oscillator block (no external crystal required)
Auto-Wake-up on Start bit
Auto-Baud Detect
10-bit, up to 11-channel Analog-to-Digital CONVERTER module (A/D), up to 100 Ksps
Auto-acquisition capability
Conversion available during Sleep
Dual analog comparators with input multiplexing
ECAN Module Features:
Message bit rates up to 1 Mbps
Conforms to CAN 2.0B ACTIVE Specification
Fully backward compatible with PIC18XXX8 CAN MODULES
Three modes of operation:
Legacy, Enhanced Legacy, FIFO
Three dedicated transmit buffers with prioritization
Two dedicated receive buffers
Six programmable receive/transmit buffers
Three full 29-bit acceptance masks
16 full 29-bit acceptance filters w/ DYNAMIC association
DeviceNet™ data byte filter support
Automatic REMOTE frame HANDLING
ADVANCED error management features
