Atmel 公司的ATMEGA88是带有8KB在系统编程Flash的8位微控制器,它是基于增强RISC架构,有丰富的指令集和32个通用的工作寄存器,吞吐量达到1 MIPS /MHz, 广泛应用于汽车电子和工业控制等领域。本文介绍了ATmega88的主要性能,方框图以及用于汽车马达控制的开发板ATAVRAUTO200的主要性能与详细电路图。
ATmega88 8-bit MICROCONTROLLER with 8K Bytes In-System Programmable Flash
The ATmega48/88/168 is a low-power CMOS 8-bit microcontroller based on the AVR enhanced RISC architecture. By execut ing powerful inst ruct ions in a SINGLE clock cycle, the ATmega48/88/168 achieves throughputs approaching 1 MIPS per MHz allowing the system designer to optimize power consumption versus processing speed.
The AVR core combines a rich instruction set with 32 GENERAL purpose working registers. All the 32 registers are directly connected to the Arithmetic Logic Unit (ALU), allowing two independent registers to be accessed in one single instruction executed in one clock cycle. The resulting architecture is more code efficient while achieving throughputs up to ten times faster than conventional CISC microcontrollers.
The ATmega48/88/168 provides the following features: 4K/8K/16K bytes of In-System Programmable Flash with Read-While-Write capabilities, 256/512/512 bytes EEPROM, 512/1K/1K bytes SRAM, 23 general purpose I/O lines, 32 general purpose working registers, three flexible Timer/Counters with compare modes, internal and external interrupts, a serial programmable USART, a byte-oriented 2-wire Serial INTERFACE, an SPI serial port, a 6-channel 10-bit ADC (8 channels in TQFP and QFN packages), a programmable Watchdog Timer with internal Oscillator, and five SOFTWARE selectable power saving modes. The Idle mode stops the CPU while allowing the SRAM, Timer/Counters, USART, 2-wire Serial Interface, SPI port, and interrupt system to continue functioning. The Power-down mode saves the register contents but freezes the
Oscillator, disabling all other chip functions until the next interrupt or HARDWARE reset. In Powersave mode, the asynchronous timer continues to run, allowing the user to maintain a timer base while the rest of the DEVICE is sleeping. The ADC Noise Reduction mode stops the CPU and all I/O MODULES except asynchronous timer and ADC, to minimize SWITCHING noise during ADC conversions.
In Standby mode, the crystal/resonator Oscillator is running while the rest of the device
is sleeping. This allows very fast start-up combined with low power consumption.
ATmega88主要特性:
High Performance, Low Power AVR® 8-Bit Microcontroller
ADVANCED RISC Architecture
131 Powerful Instructions – Most Single Clock Cycle Execution
32 x 8 General Purpose Working Registers
Fully Static Operation
Up to 16 MIPS Throughput at 16 MHz
On-chip 2-cycle Multiplier
Non-volatile Program and Data Memories
4/8/16K Bytes of In-System Self-Programmable Flash (ATmega48/88/168)
Endurance: 75,000 Write/Erase Cycles
Optional Boot Code Section with Independent Lock Bits
In-System PROGRAMMING by On-chip Boot Program
True Read-While-Write Operation
256/512/512 Bytes EEPROM (ATmega48/88/168)
Endurance: 100,000 Write/Erase Cycles
512/1K/1K Byte Internal SRAM (ATmega48/88/168)
Programming Lock for Software SECURITY
Peripheral Features
Two 8-bit Timer/Counters with Separate Prescaler and Compare Mode
One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture
Mode
Real Time Counter with Separate Oscillator
Six PWM Channels
8-channel 10-bit ADC
Programmable Serial USART
Master/Slave SPI Serial Interface
Byte-oriented 2-wire Serial Interface
Programmable Watchdog Timer with Separate On-chip Oscillator
On-chip ANALOG Comparator
Interrupt and Wake-up on Pin Change
Special Microcontroller Features
Power-on Reset and Programmable Brown-out Detection
Internal Calibrated Oscillator
External and Internal Interrupt Sources
Five Sleep Modes: Idle, ADC Noise Reduction, Power-save, Power-down, and
Standby
I/O and Packages
23 Programmable I/O Lines
Green/ROHS 32-lead TQFP and 32-pad QFN
Operating VOLTAGE:
2.7 - 5.5V for ATmega48/88/168
Temperature Range:
40C to 125C
Speed Grade:
ATmega48/88/168: 0 - 8 MHz @ 2.7 - 5.5V, 0 - 16 MHz @ 4.5 - 5.5V
Low Power Consumption
ACTIVE Mode:
4 MHz, 3.0V: 1.8mA
ATmega88开发板ATAVRAUTO200
This document describes the ATAVRAUTO200 dedicated to the ATmega88 AVR micro
controllers. This board is designed to allow an easy EVALUATION of the product using
demonstration firmware.
This board includes all elements necessary for designers to quickly develop code related to LIN communication node implementing the ATmega88 and for prototyping and TESTING of new designs.
