嵌入式 > 技术百科 > 详情
NS气象遥控检测解决方案
发布时间:2023-10-08 发布时间:
Gadgets that inform the consumer of temperature and barometric changes, such as a meteorological REMOTE sensing unit, are becoming more popular as these DEVICES are able predict the weather with more PRECISION and accuracy. NATIONAL completes the ANALOG signal chain beginning with temperature SENSORS, conditioning through operational amplifiers, converting to DIGITAL with A/D converters, then either storing into MEMORY or displaying using Nationals display technology.
Component Highlights
* Temperature sensor - digital and analog sensors have accuracies of 0.5-1degC, and, with current OUTPUT or two-wire INTERFACE, are ideal for remote sensing applications.
* Operational amplifier - precision RRIO low-power amplifiers include high-impedance CMOS devices to minimize loading of sensors and have a wide supply range to accommodate a variety of BATTERY voltages.
* A/D converter - high 10-bit or greater resolution and accuracy of 1lsb or better enable high quality instrumentation, while SOFTWARE powerdown saves power.
* LDO - ultra-low dropout voltage with excellent supply rejection near dropout keep SYSTEM performance high over the life of the battery
1 Shaded Temp
LM63CIMA
LM63CIMAX
LM73CIMK-0
2 UnShaded Temp
LM63CIMA
LM63CIMAX
LM73CIMK-0
3 Digital Temperature Sensors
LM99CIMM
LM99-1CIMM
LM63CIMAX
4 Amp
LMP7701MF
LMP7701MFX
LMP7704MT
5 MUX
DS90CP22MX-8
DS90CP22MTX
DS90CP22MT
6 Reference
LM4120
LM4125
LM4140
7 ADC
ADC101S101
ADC102S021
ADC104S021
8 MICROCONTROLLER
LMV225
LMV226
LMV228
9 LCD Panel
As display manufactures lower prices, improve performance, extend display size ranges, and adopt new, innovative form factors, they are penetrating a wider range of applications. Design your displays using Nationals expertise in portable applications and innovative packaging.
* TFT panel MODULE - LM2702 is a compact bias solution, with INTEGRATED Vcom and Gamma buffers, ideal for large screen LCD panels.
* Panel timing controller - with LVDS technology, these controllers have programmable outputs with customized control for STANDARD or in-house column drivers and row drivers.
* Vcom reference amplifier - LM8262 is a RRIO operational amplifier specifically designed to handle the Vcom driver requirements of TFT flat panels.
* Audio amplifier - Overture® amplifiers deliver audio power with high efficiency and require few external COMPONENTS, making them ideal for slim LCD panels
(1) Integrated LVDS Rx+Tcon
DS90C3201VS
DS90C3202VS
DS90C365AMT
(2) Gamma Reference Voltage
LMP7701
LMP7704
LMP8270
(3) Vcom Reference
LMH6624
LMH6626
LMH6628
(4) TFT Panel MODULES
DS90C3201VS
DS90C3202VS
DS90C365AMT
(5) SWITCHING REGULATOR
(6) LDO
LP2997
LP38690
LP38691
10 Ethernet
DP83847ALQA56AX
DP83847ALQA56A
DP83848TSQ
11 Voltage Regulator
LM2936
LP2966
LP2967
浅谈IP技术在网络电视中的应用
