嵌入式 > 技术百科 > 详情
19264液晶屏与单片机驱动
发布时间:2024-10-29 发布时间:
首先说下19264屏
1926屏是由3个64*64 组成   64行     192列     其中192列 是64+64+64 =192
它们分别有CS1  CS2  CS3 控制  让那个屏显示 所以  每个屏最多只能显示64行64列    切结8行 等于1页。
每页只能最多写8行 64列,8*64 =512位   512/8 =64字节最多写64字节 。。以上就是19264液晶屏的基本原理,虽然各个厂商硬件有所差异但原理基本相同。
以下给之前项目中使用的AT-C19264的驱动部分代码仅供参考!
 C++ Code
#include "main.h"
#define  __LCD_C__
const uchar code jie[]={
0x08,0x08,0x08,0xFF,0x88,0x68,0x24,0x2C,0xB4,0x25,0x26,0x34,0x2C,0x24,0x20,0x00,
0x02,0x42,0x81,0x7F,0x02,0x82,0x8A,0x4E,0x53,0x32,0x12,0x2E,0x42,0xC2,0x02,0x00   //"接",0
const uchar code di[]={
0x10,0x10,0x10,0xFE,0x10,0x50,0x40,0xFE,0x20,0x20,0xFF,0x10,0x10,0xF8,0x10,0x00,
0x20,0x20,0x10,0x1F,0x08,0x08,0x00,0x3F,0x40,0x40,0x4F,0x42,0x44,0x43,0x70,0x00//"地",1
const uchar code zu[]={
0x00,0xFF,0x11,0x29,0xC7,0x01,0xFE,0x22,0x22,0x22,0x22,0x22,0xFE,0x00,0x00,0x00,
0x00,0xFF,0x02,0x04,0x43,0x40,0x7F,0x42,0x42,0x42,0x42,0x42,0x7F,0x40,0x40,0x00//"阻",3
const uchar code ce[]={
0x08,0x31,0x86,0x60,0x00,0xFE,0x02,0xF2,0x02,0xFE,0x00,0xF8,0x00,0x00,0xFF,0x00,
0x04,0xFC,0x03,0x00,0x80,0x47,0x30,0x0F,0x10,0x67,0x00,0x07,0x40,0x80,0x7F,0x00//"测",0
const uchar code shi[]={
0x40,0x42,0xDC,0x08,0x00,0x90,0x90,0x90,0x90,0x90,0xFF,0x10,0x12,0x1C,0x10,0x00,
0x00,0x00,0x7F,0x20,0x10,0x20,0x20,0x1F,0x10,0x10,0x01,0x06,0x18,0x20,0x78,0x00//"试",1
const uchar code dian[]={
0x00,0x00,0xF8,0x48,0x48,0x48,0x48,0xFF,0x48,0x48,0x48,0x48,0xF8,0x00,0x00,0x00,
0x00,0x00,0x0F,0x04,0x04,0x04,0x04,0x3F,0x44,0x44,0x44,0x44,0x4F,0x40,0x70,0x00,//"电",2
const uchar code liu[]={
0x10,0x60,0x01,0x86,0x60,0x04,0x44,0x64,0x55,0x4E,0x44,0x64,0xC4,0x04,0x04,0x00,
0x04,0x04,0xFC,0x03,0x40,0x30,0x0F,0x00,0x00,0x7F,0x00,0x3F,0x40,0x40,0x70,0x00//"流",3
const uchar code si[]={
0x00, 0xFC, 0x44, 0x44, 0x44, 0xFC, 0x10, 0x90, 0x10, 0x10, 0x10, 0xFF, 0x10, 0x10, 0x10, 0x00,
0x00, 0x07, 0x04, 0x04, 0x04, 0x07, 0x00, 0x00, 0x03, 0x40, 0x80, 0x7F, 0x00, 0x00, 0x00, 0x00//"时",0
const uchar code jian[]={
0x00, 0xF8, 0x01, 0x06, 0x00, 0xF0, 0x92, 0x92, 0x92, 0x92, 0xF2, 0x02, 0x02, 0xFE, 0x00, 0x00,
0x00, 0xFF, 0x00, 0x00, 0x00, 0x07, 0x04, 0x04, 0x04, 0x04, 0x07, 0x40, 0x80, 0x7F, 0x00, 0x00//"间",1
const uchar code bao[]={
0x08,0x08,0x88,0xFF,0x48,0x28,0x00,0xFF,0xC1,0x41,0x41,0x49,0x51,0xCF,0x00,0x00,
0x01,0x41,0x80,0x7F,0x00,0x00,0x00,0xFF,0x40,0x23,0x14,0x1C,0x33,0x60,0x20,0x00
const uchar code jing[]={
0x20,0x1A,0xFA,0xAF,0xAA,0xEF,0x0A,0xFA,0x10,0x8F,0x54,0x24,0x5C,0x84,0x04,0x00,
0x02,0x02,0x02,0xEA,0xAA,0xAA,0xAB,0xAA,0xAB,0xAA,0xAA,0xEA,0x02,0x02,0x03,0x00
const uchar code bu[]={
0x08,0x08,0x89,0xCE,0x2A,0x98,0x48,0x00,0x00,0x00,0xFF,0x20,0x40,0x80,0x00,0x00,
0x02,0x01,0x00,0xFF,0x01,0x02,0x04,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x03,0x00
const uchar code cang[]={
0x40,0x20,0xF8,0x27,0x02,0x30,0x92,0x9C,0x90,0x9F,0x90,0x98,0x96,0x34,0x10,0x00,
0x00,0x00,0x7F,0x00,0x00,0x22,0x72,0x2A,0x2E,0x22,0x22,0x2A,0x72,0x22,0x02,0x00
const uchar code zero[]={
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,   //"0",
0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,   //"1",
0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,   //"2",
0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,   //"3",
0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,   //"4",
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,   //"5",
0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,   //"6",
0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,   //"7",
0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,   //"8",
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,    //"9",
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00     //"."
const uchar code m[]={
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x20,0x3F,0x20,0x00,0x3F,0x20,0x00,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
const uchar code R[]={
0x00,0x00,0xC0,0x20,0x10,0x08,0x08,0x08,0x08,0x08,0x10,0x20,0xC0,0x00,0x00,0x00,
0x00,0x38,0x23,0x24,0x28,0x30,0x00,0x00,0x00,0x30,0x28,0x24,0x23,0x38,0x00,0x00
const uchar code A[]={
0x00,0x00,0xC0,0x38,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x20,0x3C,0x23,0x02,0x02,0x27,0x38,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
const uchar code S[]={
0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
void delay_ms(uint dly)     //@6MHz
    unsigned char i, j;
    while(dly!=0){
        //_nop_();
        //_nop_();
        dly--;
        i = 6;
        j = 210;
        do
            while (--j);
        } while (--i);
void send_bt(uint bty){
    uchar i;
    for (i=0;i<8;i++){
        clk164 =0;
        if (bty & 0x80)
            dat164 = 1;
        else
            dat164 = 0;
        clk164 = 1;
        bty = bty << 1;
void lcd_write_command(uchar cmd){
    //while(busy()); //返回1  死循环  测试忙
    lcd_di =0;
    lcd_rw =0;
    send_bt(cmd);
    lcd_e =1;
    //delay(1);
    _nop_();
    lcd_e =0;
void lcd_write_data(uchar dat){
    lcd_di =1;
    lcd_rw =0;
    send_bt(dat);
    lcd_e =1;
    //delay(1);//防止  写数据 与写指令频率太快
    _nop_();
    lcd_e =0;
void set_line(uchar line){
    lcd_di =0;
    lcd_rw =0;
    line = 0xc0 | line;
    lcd_write_command(line);
void set_page(uchar page){
    lcd_di = 0;
    lcd_rw = 0;
    page = 0xb8 | page;
    lcd_write_command(page);
void set_column(uchar col){
    lcd_di = 0;
    lcd_rw = 0;
    col = col & 0x3f;
    col = 0x40 | col;
    lcd_write_command(col);
void select_screen(uchar swich){
    //swich = 0x07 & swich;
    switch(swich)
        case 0:
            {lcd_cs1=lcd_cs2=lcd_cs3 =0;
            break;}
        case 1:
            {lcd_cs1=lcd_cs2 =0;
            lcd_cs3 = 1;
            break;}
        case 2:
            {lcd_cs1=lcd_cs3 = 0;
            lcd_cs2 =1;
            break;}
        case 3:
            {lcd_cs1=0;
            lcd_cs2=lcd_cs3 = 1;
            break;}
        case 4:
            {lcd_cs1=1;
            lcd_cs2=lcd_cs3=1;
            break;}
        case 5:
            {lcd_cs1=lcd_cs3=1;
            lcd_cs2 =0;
            break;}
        case 6:
            {lcd_cs1=lcd_cs2=1;
            lcd_cs3=0;
            break;}
        case 7:
            {lcd_cs1=lcd_cs2=lcd_cs3=1;
            break;}
        default:
                break;
void set_on_off(uchar swich){
    lcd_di = 0;
    lcd_rw = 0;
    swich = 0x3e | swich;
    lcd_write_command(swich);
void lcd_scr_clr(void){
    uchar i,j;
    lcd_cs1 =lcd_cs2 = lcd_cs3 =0;
    set_line(0);
    set_on_off(1);
    set_column(0);
    for (i=0;i<8;i++){
        set_page(i);
        for (j=0;j<64;j++){
            lcd_write_data(0x00);
void lcd_init(void){
    //while(busy()); //返回1  死循环  防止更改PO口继电器
    clr164=1;
    lcd_rst=1;
    lcd_scr_clr();
    set_line(0);//这里是设置起始行
void display(uchar screen ,uchar page,uchar col,uchar *p){
    uchar i;
    select_screen(screen);
    set_page(page);
    set_column(col);
    for (i=0;i<16;i++){
        lcd_write_data(p[i]);
    set_page(page +1);
    set_column(col);
    for (i=0;i<16;i++){
        lcd_write_data(p[i+16]);
void display_word(void){
    display(3,0,0,jie);
    display(3,0,16,di);
    display(3,0,32,dian);
    display(3,0,48,zu);
    display(3,3,0,ce);
    display(3,3,16,shi);
    display(3,3,32,dian);
    display(3,3,48,liu);
    display(3,6,0,ce);
    display(3,6,16,shi);
    display(3,6,32,si);
    display(3,6,48,jian);
    display(6,0,32,m);
    display(6,0,41,R);
    display(6,3,32,A);
    display(6,6,32,S);
void display_word_current(void)
    display(3,3,0,ce);
    display(6,3,32,A);
void display_word_time(void)
    display(3,6,0,ce);
    display(3,6,32,si);
    display(6,6,32,S);
void display_word_offset(void)
    display(3,6,0,bu);
    display(3,6,16,cang);
    display(3,6,32,dian);
    display(3,6,48,zu);
    display(6,6,32,m);
    display(6,6,41,R);
void display_word_alarm(void)
    display(3,3,0,bao);
    display(3,3,16,jing);
    display(3,3,48,zu);
    display(6,3,32,m);
    display(6,3,41,R);
void show_sit(uchar screen,uchar row,uchar x_sit,uchar y_sit)reentrant{
    set_line(row);
    set_page(x_sit);
    set_column(y_sit);
void display_current(uint test_current ){
    uint timh1,timh2,timh3;
    uint i;
    //10    25    100
    timh1 = test_current/100%10;  //百位
    timh2 = test_current/10%10; //取出10位
    timh3 = test_current% 10;//个位
    show_sit(5,63,3,40);
    for (i=0;i<8;i++)
        lcd_write_data(zero[timh1*16+i]);
    show_sit(5,63,4,40);
    for(i=0;i<8;i++)
        lcd_write_data(zero[timh1*16+i+8]);
    show_sit(5,63,3,48);
    for (i=0;i<8;i++)
        lcd_write_data(zero[timh2*16+i]);
    show_sit(5,63,4,48);
    for(i=0;i<8;i++)
        lcd_write_data(zero[timh2*16+i+8]);
    show_sit(5,63,3,56);
    for (i=0;i<8;i++)
        lcd_write_data(zero[timh3*16+i]);
    show_sit(5,63,4,56);
    for(i=0;i<8;i++)
        lcd_write_data(zero[timh3*16+i+8]);
 void display_time(uint test_time) reentrant {
    uint timh1,timh2;
    uint i;
    timh1 = test_time/10%10;//取出 十位
    timh2 = test_time%10;//取出 个位
    show_sit(5,63,6,40);
    for (i=0;i<8;i++)
        lcd_write_data(zero[ timh1*16+i]);
    show_sit(5,63,7,40);
    for(i=0;i<8;i++)
    show_sit(5,63,6,48);
    for (i=0;i<8;i++)
    show_sit(5,63,7,48);
    for(i=0;i<8;i++)
void display_offset(uchar offset_R)
    uint timh1,timh2;
    uint i;
    timh1 = offset_R/10%10;//取出 十位
    timh2 = offset_R%10;//取出 个位
    for (i=0;i<8;i++)
    for(i=0;i<8;i++)
    for (i=0;i<8;i++)
    for(i=0;i<8;i++)
void display_alarm(uchar alarm_R)
    uint i;
    timh1 = alarm_R/100%10;//取出 百位位
    timh2 = alarm_R/10%10;//取出 十位位
    timh3 = alarm_R%10;//取出个位
    show_sit(5,63,3,32);
    for (i=0;i<8;i++)
    show_sit(5,63,4,32);
    for(i=0;i<8;i++)
    for (i=0;i<8;i++)
    for(i=0;i<8;i++)
    for (i=0;i<8;i++)
    for(i=0;i<8;i++)
void display_result(uint jd_dz){
    uchar timh1,timh2,timh3,timh4;
    uchar row;
    timh1 = jd_dz/1000;
    timh2 = jd_dz%1000/100;
    timh3 = jd_dz %1000%100/10;
    timh4 = jd_dz%1000%100%10;
    show_sit(5,63,0,40);
    for(row=0;row<8;row++)
        lcd_write_data(zero[timh1*16+row]);
    show_sit(5,63,1,40);
        lcd_write_data(zero[timh1*16+row+8]);   //zero这个数组拆开的
    show_sit(5,63,0,48);
            lcd_write_data(zero[timh2*16+row]);
    show_sit(5,63,1,48);
    for(row=0;row<10;row++)
            lcd_write_data(zero[timh2*16+row+8]);   //高2位
    show_sit(5,63,0,56);
            lcd_write_data(zero[timh3*16+row]);
    show_sit(5,63,1,56);
            lcd_write_data(zero[timh3*16+row+8]);
    show_sit(6,63,0,0);
            lcd_write_data(zero[timh4*16+row]);
    show_sit(6,63,1,0);
            lcd_write_data(zero[timh4*16+row+8]);//后2位
    //难道是共阴共阳极点阵 发 10列数据? 2页   10*16 发得都是列数据
浅谈IP技术在网络电视中的应用
