MSP430 ADC10单通道多次转换
#include "msp430x22x4.h"
#define uchar unsigned char
#define uint unsigned int
#define LCDen 0X80; //P3的高三位做控制线
#define lcdrw 0X40;
#define lcdrs 0X20;
void delay(uint z) //延时程序
uint x,y;
for(x=z;x>0;x--)
for(y=100;y>0;y--);
void write_com(uchar com) //写指令
P3OUT&=~lcdrs;
P4OUT=com;
delay(5);
P3OUT |= lcden;
delay(5);
P3OUT &= ~lcden;
void write_data(uchar date) //写数据
P3OUT|=lcdrs;
P4OUT=date;
delay(5);
P3OUT|=lcden;
delay(5);
P3OUT &= ~lcden;
void init() //初始化
P3OUT &= ~lcdrw;
P3OUT &= ~lcden;
write_com(0x38);//显示模式设置
write_com(0x0f);//
write_com(0x06);//
write_com(0x01);//
write_com(0x80+0x00);//
uchar num;
uchar table[]="0123456789";
uint dada[5];
volatile float ad_value;
void main( void )
WDTCTL=WDTPW+WDTHOLD; //关看门狗
BCSCTL1 =CALBC1_1MHz; //设定DCO 为1MHZ
DCOCTL =CALBC1_1MHZ;
P2SEL = 0X01;
P3SEL=0X00;
P3DIR=0XFF;
P3OUT=0X00;
P4SEL=0X00;
P4DIR=0XFF;
P4OUT=0X00;
init();
//时钟源选AD 内部时钟并4 分频,选通道10,AD 启动信号来源选TA.OUT1,选单通道连续采样
ADC10CTL1=ADC10DIV_3+INCH_0+SHS_1+CONSEQ_2;
//选1.5V 为正向参考,地为负参考,AD 中断使能,打开参考,启动AD 模块(不是启动AD 转换)
ADC10CTL0=SREF_1+ADC10SHT_3+ADC10IE+REFON+ADC10ON+REF2_5V;
TACCR0=30; //延时等待参考稳定
TACCTL0 |=CCIE; //CCR0 中断使能
TACTL=TACLR+MC_1+TASSEL_2; //TA 增计数,时钟源为smclk
_BIS_SR(LPM0_bits+GIE); //进入低功耗0,使能总中断,等待参考稳定
TACCTL0 &=~CCIE; //CCR0 中断禁止
_BIC_SR(GIE); //关总中断
ADC10CTL0 |=ENC; //AD 转换使能
TACCTL1=OUTMOD_4; //CCR1 选输出模式4,当TAR=0 时,输出高电平
TACTL =TASSEL_2+MC_2; //TA 改为连续计数,smclk 时钟源
while(1)
_BIS_SR(LPM0_bits+GIE); //进入低功耗0,使能总中断,等待10AD 完成
for(num=0;num<5;num++)
write_data(table[dada[num]]);
delay(5);
_BIS_SR(GIE);
#pragma vector = TIMERA0_VECTOR //TA0 中断服务,用来参考稳定
__interrupt void ta0_isr(void)
TACTL=0; //关TA
_BIC_SR_IRQ(LPM0_bits); //退出低功耗
#pragma vector = ADC10_VECTOR //ADC10 中断服务
__interrupt void adc_isr(void)
ad_value=ADC10MEM/409.2; //保存AD 结果
for(uchar i=0;i<5;i++)
dada[i]=ad_value;
ad_value=ad_value-dada[i];
ad_value=ad_value*10;
_BIC_SR(GIE);
