#include
unsigned char I2CBUF;
unsigned char checkbit;
#define SCL_H (P10OUT |= BIT2) // P10.2为SCL
#define SCL_L (P10OUT &= ~BIT2)
#define SDA_H (P10OUT |= BIT1) //p10.1为SDA
#define SDA_L (P10OUT &= ~BIT1)
#define SDA_OUT (P10DIR |= BIT1)
#define SDA_IN (P10DIR &= ~ BIT1)
void I2C_Start(void) //I2C开始信号
SDA_OUT;
SCL_L;
SDA_H;
__delay_cycles(5);
SCL_H;
__delay_cycles(5);
SDA_L;
__delay_cycles(5);
SCL_L;
__delay_cycles(5);
unsigned char testACK(void) {
SDA_IN;
__delay_cycles(5);
SCL_H;
__delay_cycles(5);
checkbit = (P10IN & BIT1) >> 4;
__delay_cycles(5);
SCL_L;
__delay_cycles(5);
return (checkbit);
void I2C_ACK(void) //应答信号
SDA_OUT;
SCL_L;
SDA_L;
__delay_cycles(5);
SCL_H;
__delay_cycles(5);
SCL_L;
__delay_cycles(5);
SDA_H;
void I2C_NACK(void) {
SDA_OUT;
SDA_H;
__delay_cycles(5);
SCL_H;
__delay_cycles(5);
SCL_L;
__delay_cycles(5);
void I2C_STOP(void) //产生结束信号
SCL_L;
__delay_cycles(5);
SDA_L;
__delay_cycles(5);
SCL_H;
__delay_cycles(5);
SDA_H;
__delay_cycles(5);
void I2C_WRITE(unsigned char data)
SDA_OUT;
unsigned char i;
for (i = 8; i > 0; i--) //高位循环8次,发送1个字节数据
if (data & 0x80) //判断数据高位是0还是1
SDA_H; //高位数据写1
else
SDA_L;
SCL_H;
__delay_cycles(5); //发送数据
SCL_L;
__delay_cycles(5);
data <<= 1;
unsigned char I2C_READ(void)
unsigned char j;
unsigned char BUFFER = 0X00;
SDA_IN;
for (j = 8; j >0; j--) //高位循环8次,发送1个字节数据
SCL_H;
__delay_cycles(5);
BUFFER <<= 1;
if ((P10IN & BIT1) == BIT1) //判断数据高位是0还是1
BUFFER |= 0X01; //高位数据写1
else
BUFFER |= 0XFE;
SCL_L;
__delay_cycles(5);
return BUFFER;
void C16_WRITEDATA(unsigned char address, unsigned char DATA)
I2C_Start();
I2C_WRITE(address);
testACK();
I2C_ACK();
I2C_WRITE(0x00);
testACK();
I2C_ACK();
I2C_WRITE(DATA);
I2C_STOP();
unsigned char C16_READEDATA(unsigned char address)
unsigned char READDATA;
I2C_Start();
I2C_WRITE(0XA1);
testACK();
I2C_ACK();
I2C_WRITE(address);
I2C_Start();
testACK();
I2C_ACK();
I2C_WRITE(0XA1);
READDATA = I2C_READ();
I2C_STOP();
return READDATA;
int main(void)
const int DATA = 0X88;
unsigned char READBUFFER;
WDTCTL = WDTPW + WDTHOLD;
P10DIR |= BIT1 + BIT2;
P2DIR |= BIT0;
P2OUT &= ~BIT0;
C16_WRITEDATA(0X00, DATA);
__delay_cycles(5);
READBUFFER = C16_READEDATA(0X00);
while (1)
if (READBUFFER == 0X88)
P2OUT |= BIT0;
} else {
P2OUT &= ~ BIT0;
__delay_cycles(15);
