本文以STM8S103F3P6编程为例,介绍STM8S103F3P6串口中断接收。
电脑平台:Windows7 64位旗舰
编译软件:IAR
硬件平台:STM8S103F3P6
1.系统时钟初始化为内部16M
CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1); //时钟 初始化时钟为1分频 16M 2分频8M
2.初始化串口
UART1_DeInit();
UART1_Init((u32)9600, UART1_WORDLENGTH_8D, UART1_STOPBITS_1, UART1_PARITY_NO, UART1_SYNCMODE_CLOCK_DISABLE, UART1_MODE_TXRX_ENABLE);
UART1_ITConfig(UART1_IT_RXNE_OR, ENABLE);
UART1_Cmd(ENABLE);
enableInterrupts();
3.编写主函数
void main(void)
Init_UART1();
enableInterrupts();
/* Infinite loop */
while (1)
if(flagpacker)
flagpacker = 0;
for(unsigned char num = 0; num < length;num++)
Send(Rxpacker[num]);
4.编写中断服务函数
unsigned char flagpacker; //全局变量 是否完整接收一个数据包
unsigned char Rxpacker[255]; //全局变量 完整数据包
unsigned char length; //数据长度
INTERRUPT_HANDLER(UART1_RX_IRQHandler, 18)
/* In order to detect unexpected events during development,
it is recommended to set a breakpoint on the following instruction.
unsigned char RxBuf; //临时接收
static unsigned char RxData[255];//接收数据缓存区
static unsigned char count; //串口接收数据长度
static unsigned char rec; // 判断是否正在接收数据
UART1_ClearITPendingBit(UART1_IT_RXNE);
RxBuf = UART1_ReceiveData8();
if(RxBuf == (0xcc)) //帧头
rec= 1;
count = 0;
flagpacker = 0;
return ;
if(RxBuf == (0xcd)) //帧尾
rec= 0;
//此处可以添加校验码
length = count;
for(unsigned char i = 0; i
Rxpacker[i] =RxData[i];
flagpacker = 1;//告诉系统已接收一个完整的数据包
return ;
if(rec) //判断是否处于接收状态
RxData[count++] = RxBuf;
