#define uint unsigned int #define uchar unsigned char sbit d1=P1^0; sbit dula=P2^6; sbit wela=P2^7; sbit Key1=P3^4; uchar code table[]={ 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f, 0x6f,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39, 0x5e,0x79,0x71 }; uchar num; void delay(uint z) { uint x,y; for(x=z;x>0;x--) for(y=110;y>0;y--); } void main() { wela=1; P0=0xfe; wela=0; P3=0xff; while(1) { if (Key1==0) {delay(10); if (Key1==0) { d1=0; num++; if(num==10) num=0; } while(!Key1); delay(10); while(!Key1); } else d1=1; dula=1; P0=table[num]; dula=0; } }
