这篇文章主要来写一下12864液晶显示的程序,至于一些寄存器的设置,和12864液晶的资料介绍,大家可以参看12864液晶的datesheet,上面一般都很全面,一些具体注意事项请大家参看:http://hi.baidu.com/echoas 他的空间里面介绍的比较清楚,我在这里也没必要浪费时间重复了。
我在这里直接贴出程序,程序注释比较清楚,相信大家对照dateshee可以看明白。
/************************************ 程序功能:无字库12864液晶的显示 编译环境:keil4 运行环境:proteus7.7 整理人:张家越 QQ:435835181 整理时间:2011-04-28 取模软件使用的是:ZM201 ***********************************/ #include#define uchar unsigned char #define uint unsigned int #define port P0 //DB0~DB7数据口 sbit e=P2^0;//使能 sbit rw=P2^1;//读写 sbit rs=P2^2;//数据/命令 sbit cs2=P2^3;//片选 sbit cs1=P2^4; sbit busy=P0^7;//检测忙 uchar code hz[][32]={ /*-- 文字: 书 --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x00,0x00,0x00,0x10,0x10,0x10,0xFF,0x88,0x88,0xFA,0x82,0x84,0x8C,0x00,0x00,0x00, 0x00,0x01,0x01,0x01,0x01,0x01,0x7F,0x00,0x00,0x08,0x10,0x0C,0x03,0x00,0x00,0x00}, /*-- 文字: 山 --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0xE0,0x00,0x00,0x00, 0x00,0x00,0x00,0x3F,0x20,0x20,0x20,0x1F,0x10,0x10,0x10,0x10,0x3F,0x00,0x00,0x00}, /*-- 文字: 有 --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x00,0x10,0x10,0x90,0x50,0xF0,0x4C,0x4B,0x28,0x28,0x28,0xE8,0x08,0x08,0x00,0x00, 0x00,0x02,0x01,0x00,0x00,0x7F,0x0A,0x0A,0x05,0x05,0x20,0x7F,0x00,0x00,0x00,0x00}, /*-- 文字: 路 --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x00,0x00,0x3C,0x24,0xE2,0x9E,0x20,0x18,0x97,0x64,0x54,0x8C,0x00,0x00,0x00,0x00, 0x00,0x10,0x1F,0x08,0x0F,0x04,0x02,0x7D,0x24,0x22,0x12,0x1E,0x01,0x01,0x01,0x00}, /*-- 文字: 勤 --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x00,0x08,0x88,0xBF,0xE4,0x54,0x5F,0xC4,0x44,0xC0,0x3F,0x20,0xE0,0x00,0x00,0x00, 0x00,0x20,0x2B,0x2A,0x1F,0x15,0x55,0x31,0x0C,0x23,0x40,0x30,0x0F,0x00,0x00,0x00}, /*-- 文字: 为 --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x00,0x00,0x00,0x40,0x44,0x58,0xC0,0x38,0x27,0x20,0x20,0xE0,0x00,0x00,0x00,0x00, 0x00,0x40,0x20,0x10,0x08,0x06,0x01,0x10,0x21,0x46,0x30,0x0F,0x00,0x00,0x00,0x00}, /*-- 文字: 径 --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x00,0x10,0x88,0xC4,0x33,0x40,0x44,0x24,0x22,0x12,0x9A,0xA6,0xA0,0x40,0x00,0x00, 0x02,0x01,0x00,0x7F,0x00,0x20,0x21,0x21,0x21,0x1F,0x10,0x10,0x10,0x10,0x00,0x00}, /*-- 文字: , --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x2C,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}, /*-- 文字: 学 --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x00,0x60,0x20,0xA0,0xA2,0xAC,0x51,0x56,0xD0,0x5C,0x13,0x10,0x30,0x10,0x00,0x00, 0x00,0x04,0x04,0x04,0x04,0x24,0x44,0x3F,0x02,0x02,0x02,0x02,0x02,0x02,0x00,0x00}, /*-- 文字: 海 --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x20,0x40,0x04,0xC8,0x20,0x10,0xCC,0x4B,0xA8,0x28,0x24,0xE4,0x04,0x00,0x00,0x00, 0x00,0x10,0x3E,0x01,0x02,0x1A,0x17,0x12,0x2E,0x49,0x39,0x0F,0x09,0x01,0x00,0x00}, /*-- 文字: 无 --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x00,0x00,0x40,0x44,0x44,0x44,0xC4,0x3C,0xE2,0x22,0x22,0x22,0x20,0x00,0x00,0x00, 0x00,0x40,0x20,0x10,0x08,0x06,0x01,0x00,0x1F,0x20,0x20,0x20,0x20,0x3C,0x00,0x00}, /*-- 文字: 涯 --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x00,0x20,0x40,0x02,0xC4,0x00,0xFC,0x24,0x24,0xFC,0x92,0x92,0x82,0x00,0x00,0x00, 0x00,0x10,0x3C,0x43,0x30,0x4E,0x41,0x49,0x49,0x3F,0x24,0x24,0x20,0x20,0x00,0x00}, /*-- 文字: 苦 --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x00,0x80,0x88,0x88,0x88,0x9E,0x84,0xE4,0x44,0x5F,0x44,0x44,0x44,0x40,0x00,0x00, 0x00,0x00,0x00,0x00,0x7C,0x44,0x44,0x23,0x22,0x22,0x3E,0x00,0x00,0x00,0x00,0x00}, /*-- 文字: 作 --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x80,0x40,0x20,0xF8,0x07,0x40,0x30,0x1C,0xF3,0x90,0x90,0x48,0x48,0x08,0x00,0x00, 0x00,0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x7F,0x04,0x04,0x02,0x02,0x02,0x00,0x00}, /*-- 文字: 舟 --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x00,0x00,0x00,0x00,0xF8,0x88,0x8C,0x9B,0xA4,0x84,0xFC,0x40,0x40,0x40,0x00,0x00, 0x01,0x41,0x21,0x19,0x07,0x00,0x02,0x04,0x10,0x20,0x7F,0x00,0x00,0x00,0x00,0x00}, /*-- 文字: 。 --*/ /*-- 仿宋_GB231212; 此字体下对应的点阵为:宽x高=16x16 --*/ {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x18,0x24,0x24,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}, {0x02,0xFE,0x92,0x92,0x92,0xFE,0x12,0x11,0x12,0x1C,0xF0,0x18,0x17,0x12,0x10,0x00, 0x08,0x1F,0x08,0x08,0x04,0xFF,0x05,0x81,0x41,0x31,0x0F,0x11,0x21,0xC1,0x41,0x00}, //"联",14 {0x00,0x00,0x02,0x22,0xB2,0xAA,0x66,0x62,0x22,0x11,0x4D,0x81,0x01,0x01,0x00,0x00, 0x00,0x40,0x21,0x13,0x09,0x05,0x41,0x81,0x7F,0x01,0x05,0x09,0x13,0x62,0x00,0x00}, //"系",15 {0x08,0x08,0x08,0x08,0x08,0x08,0xF9,0x4A,0x4C,0x48,0x48,0xC8,0x08,0x08,0x08,0x00, 0x40,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x20,0x40,0x40,0x3F,0x00,0x00,0x00,0x00}, //"方",16 {0x00,0x08,0x88,0x88,0x88,0x88,0x88,0x08,0xFF,0x08,0x09,0x0E,0x0A,0x08,0x00,0x00, 0x00,0x20,0x60,0x30,0x1F,0x10,0x08,0x08,0x00,0x07,0x18,0x20,0x40,0x80,0x70,0x00}, //"式",17 }; uchar code num[][16]={ {0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00}, //"0",0 {0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00}, //"1",1 {0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00}, //"2",2 {0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00}, //"3",3 {0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00}, //"4",4 {0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00}, //"5",5 {0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00}, //"6",6 {0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00}, //"7",7 {0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00}, //"8",8 {0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00} //"9",9 }; uchar code sign[][16]={ {0x00,0x00,0x00,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x33,0x30,0x00,0x00,0x00}, //"!",0 {0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00}, //":",1 {0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x18,0x24,0x24,0x38,0x50,0x4F,0x00} //"Q",2 }; //延时 void delay(uint n) { uint i; for(;n>0;n--) for(i=200;i>0;i--); } //判断是否忙 void check() { rs=0; rw=1; //读 e=1; port=0x00; e=1; while(busy); e=0; } //写指令 void sendcommand(uchar command) { check(); rs=0; //指令 rw=0; //写 e=0; port=command; e=1; e=0; //写入指令 } //写数据 void writedata(uchar dat) { check(); rs=1; //数据 rw=0; port=dat; e=1; e=0; } //选屏幕 0--全屏,1--左屏,2--右屏; void select(uint n) { switch(n) { case 0:cs1=0;cs2=0;break; //低电平选中 case 1:cs1=0;cs2=1;break; //cs1左屏 case 2:cs1=1;cs2=0;break; //cs2右屏 } } //页 void setpage(uchar page) { page=page&0x07; page=page|0xb8; sendcommand(page); } //列 void setcolumn(uchar column) { column=column&0x3f; column=column|0x40; sendcommand(column); } //起始行 void setline(uchar line) { line=line&0x3f; line=line|0xc0; sendcommand(line); } //屏幕开关显示 0--关,1--开; void seton(uint n) { n=n|0x3e; sendcommand(n); } //清屏 0--全屏,1--左屏,2--右屏; void clear(uint n) { uchar i,j; select(n); for(i=0;i<8;i++) { setpage(i); setcolumn(0); for(j=0;j<64;j++) writedata(0); //置0清空 } } //初始化 void init(uchar i) { check(); seton(1); select(0); //clear(0); setline(i); } //显示汉字 16*16显示 void show16(uchar page,uchar column,uchar screen,uchar method,uchar *str) //页,列, { uchar i,j; select(screen); j=0; setpage(page); setcolumn(column); for(i=0;i<16;i++) { if(method==1) writedata(~str[j++]); //method为显示方式。当等于1时,反白。 else writedata(str[j++]); } setpage(page+1); setcolumn(column); for(i=0;i<16;i++) { if(method==1) writedata(~str[j++]); else writedata(str[j++]); } } //显示数字 8*16显示 void show8(uchar page,uchar column,uchar screen,uchar method,uchar *str) { uchar i,j; select(screen);j=0; setpage(page); setcolumn(column); for(i=0;i<8;i++) { if(method==1) writedata(~str[j++]); else writedata(str[j++]); } setpage(page+1); setcolumn(column); for(i=0;i<8;i++) { if(method==1) writedata(~str[j++]); else writedata(str[j++]); } } void welcome() { uint i=0,j; for(j=0;j<3;j++,j++) for(i=0;i<4;i++) { show16(j,16*i,1,0,hz[i+j*4]); //写左屏数据 // if(i+4+j*4<16) show16(j,16*i,2,0,hz[i+4+j*4]); //写右屏数据 } // show8(2,32,2,0,sign[0]); //! for(i=0;i<4;i++) { show16(4,16*i,1,0,hz[16+i]); } show8(4,0,2,0,sign[1]); //: show8(6,0,1,0,sign[2]); //Q show8(6,8,1,0,sign[2]); //Q show8(6,16,1,0,sign[1]); //: //以下数字均为反白显示。 show8(6,32,1,1,num[4]); //4 show8(6,40,1,1,num[3]); //3 show8(6,48,1,1,num[5]); //5 show8(6,56,1,1,num[8]); //8 show8(6,0,2,1,num[3]); //3 show8(6,8,2,1,num[5]); //5 show8(6,16,2,1,num[1]); //1 show8(6,24,2,1,num[8]); //8 show8(6,32,2,1,num[1]); //1 } void main() { uchar j; clear(0); while(1) { for(j=0;j<63;) { j=j+16; if(j>60) j=0; init(j); // delay(200); welcome(); delay(500); } } }
