1602液晶显示
#include
#define CPU_F ((double)8000000)
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define uchar unsigned char
#define uint unsigned int
#define ulong unsigned long
#define P10 3
#define P11 6
#define P12 7
#define RS_CLR P3OUT &= ~(1 << P10) //RS置低
#define RS_SET P3OUT |= (1 << P10) //RS置高
#define RW_CLR P3OUT &= ~(1 << P11) //RW置低
#define RW_SET P3OUT |= (1 << P11) //RW置高
#define EN_CLR P3OUT &= ~(1 << P12) //E置低
#define EN_SET P3OUT |= (1 << P12) //E置高
#define DataPort P4OUT //P4口为数据口
#define KeyPort P1IN //独立键盘接在P14~P17
#define LED P2OUT //LED灯接在P2上
uchar key;
uchar temp,keynum = 0;
int shi=23,fen=59,miao=58;
// 系统时钟初始化
void Clock_Init()
uchar i;
BCSCTL1&=~XT2OFF; //打开XT振荡器
BCSCTL2|=SELM1+SELS; //MCLK为8MHZ,SMCLK为8MHZ
do{
IFG1&=~OFIFG; //清除震荡标志
for(i=0;i<100;i++)
_NOP(); //延时等待
while((IFG1&OFIFG)!=0); //如果标志为1,则继续循环等待
IFG1&=~OFIFG;
// MSP430内部看门狗初始化
void WDT_Init()
WDTCTL = WDTPW + WDTHOLD; //关闭看门狗
// 初始化IO口子程序
void Port_init()
P1SEL = 0x00; //P2普通IO功能
P1DIR = 0x0F; //P24~P27输入模式,外部电路已接上拉电阻
P2SEL = 0x00; //P5口普通IO功能
P2DIR = 0xFF;
// LED = 0X00; //P5口输出模式
P4SEL = 0x00;
P4DIR = 0xFF;
P3SEL = 0x00;
P3DIR|= BIT3 + BIT6 + BIT7; //控制口设置为输出模式
// 显示屏命令写入函数
void LCD_write_com(unsigned char com)
RS_CLR;
RW_CLR;
EN_SET;
DataPort = com; //命令写入端口
delay_ms(5);
EN_CLR;
// 显示屏数据写入函数
void LCD_write_data(unsigned char data)
RS_SET;
RW_CLR;
EN_SET;
DataPort = data; //数据写入端口
delay_ms(5);
EN_CLR;
// 显示屏清空显示
void LCD_clear(void)
LCD_write_com(0x01); //清屏幕显示
delay_ms(5);
// 写入时分秒
void LCD_write_sfm(uchar add,uchar dat)
uchar a,b;
a = dat/10;
b = dat%10;
LCD_write_com(0xc0 + add);
LCD_write_data(a+0x30);
LCD_write_data(b+0x30);
// 显示屏字符串写入函数
void LCD_write_str(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
LCD_write_com(0x80 + x); //第一行显示
else
LCD_write_com(0xC0 + x); //第二行显示
while (*s)
LCD_write_data( *s);
s ++;
// 显示屏单字符写入函数
void LCD_write_char(unsigned char x,unsigned char y,unsigned char data)
if (y == 0)
else
LCD_write_data( data);
// 显示屏初始化函数
void LCD_init(void)
LCD_write_com(0x38); //显示模式设置
delay_ms(5);
LCD_write_com(0x08); //显示关闭
delay_ms(5);
LCD_write_com(0x01); //显示清屏
delay_ms(5);
LCD_write_com(0x06); //显示光标移动设置
delay_ms(5);
LCD_write_com(0x0C); //显示开及光标设置
delay_ms(5);
// 时钟显示
void clock(void)
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
LCD_write_sfm(2,shi);
LCD_write_sfm(5,fen);
LCD_write_sfm(8,miao);
// 按键检测
uchar Key_Scan(void)
uchar key_check;
uchar key_checkin;
key_checkin=KeyPort; //读取IO口状态,判断是否有键按下
key_checkin&= 0xF0; //读取IO口状态,判断是否有键按下
if(key_checkin!=0xF0) //IO口值发生变化则表示有键按下
delay_ms(20); //键盘消抖,延时20MS
if(key_checkin!=0xF1)
key_check=KeyPort;
switch (key_check & 0xF0)
case 0xE0:key=1;break;
case 0xD0:key=2;break;
case 0xB0:key=3;break;
case 0x70:key=4;break;
return key;
// 主程序
void main(void)
WDT_Init(); //看门狗设置
// Clock_Init(); //系统时钟设置
Port_init(); //系统初始化,设置IO口属性
delay_ms(100); //延时100ms
LCD_init(); //液晶参数初始化设置
LCD_clear(); //清屏
LCD_write_com(0xc0+4);
LCD_write_data(':');
LCD_write_com(0xc0+7);
CCR0 = 32768;
// TACTL = TASSEL_2 + MC_3; //+ MC1;
TACTL = TASSEL1 + TACLR + MC0 + ID_2;
CCTL0 |= CCIE;
_EINT();
while(1)
Key_Scan(); //键盘扫描,看是否有按键按下
if(key != 0xff) //如果有按键按下,则显示该按键键值1~4
switch(key)
case 1: _DINT();break; //给不同的键赋键值,键值1,亮1个LED灯D1
case 2: LED=0xCF;break; //给不同的键赋键值,键值2,亮1个LED灯D2
case 3: LED=0xF8;break; //给不同的键赋键值,键值3,亮2个LED灯D1.D2
case 4: LED=0xFF;break; //给不同的键赋键值,键值4,亮0个LED灯
// default:_EINT();
#pragma vector=TIMERA0_VECTOR
__interrupt void TimerA_ISR(void)
clock();
// P2OUT ^= ~BIT0;
// CCR0 += 50000;
