/*编写人:伍浩荣
8个按键发出8个基本音,
能播放内置音乐,音乐跟随灯光闪烁
版权所有,翻版必究
作者博客:http://hi.baidu.com/haorongwu/home*/
sfr P4=0xe8;//定义P4组I0口
#include
#define uint unsigned int
#define uchar unsigned char
sbit speaker=P1^4;//喇叭接30脚
sbit key1=P4^4;//流水灯按键(暂时)
sbit key2=P4^6;//播放音乐按键(暂定)
uchar a,b,num1,s1num,n1,n2;
char num;//定义num为可以负数
uchar code yinfu[]={0xfb,0xe9, //Do
0xfc,0x5c, //Re
0xfc,0xc1, //Mi
0xfc,0xef, //Fa
0xfd,0x45, //So
0xfd,0x92, //La
0xfd,0xd0, //Si
0xfd,0xee, //Do#
0x00,0x00, //间隔
uchar code shengri_tone[]={ 1,0,1,2,1,4,3,0, //生日快乐音调
1,0,1,2,1,5,4,0,
1,0,1,8,6,4,3,2,0,
7,0,7,6,4,5,4,0 //0代表不发声,即停顿;数字即为音调
uchar code shengri_beat[]={ 24,1,24,48,48,48,72,5,//节拍
24,1,24,48,48,48,48,72,5,
24,1,24,48,48,48,72,5 //节拍,即tone表各音调的延时
uchar code ledtable[]={0x7f,0xbf,0xdf,0xef, //取反
0xf7,0xfb,0xfd,0xfe};//P0组口的发光二极管代码(焊接过程可能会相反,具体更改)
uchar code ledtable2[]={0x7f,0xbf,0xdf,0xef, //取反
0xf7,0xfb,0xfd,0xfe};//P2组口发光二极管代码,相反!
void check_key();//改为P3组为按键
void keyscan();
void turn();//顺时针流动
void back();
void qianhou();
void dangshuang();
void delay(uint z);//延时函数声明
void delay1(void);//声明第二个延时函数
void play1(void);//播放生日快乐
void main()
s1num=0;//流水灯种类标志
key1=1;
key2=1;
TMOD=0x01;
TH0=a;
TL0=b;
ET0=1;//打开定时器,但是未允许中断
TR0=1;
while(1)
check_key();
keyscan();
void time0() interrupt 1
TH0=a;
TL0=b;
speaker=~speaker;
void check_key()
P3=0xff;//先赋给P2组口高电平
switch(P3)//按下一个键相应4个灯亮
case 0xfe:P0=0xee;P2=0x77;a=0xfb;b=0xe9;EA=1;break;//P0,P2组为发光二极管组
case 0xfd:P0=0xdd;P2=0xbb;a=0xfc;b=0x5c;EA=1;break;//注意:EA不能改为TR0
case 0xfb:P0=0xbb;P2=0xdd;a=0xfc;b=0xc1;EA=1;break;
case 0xf7:P0=0x77;P2=0xee;a=0xfc;b=0xef;EA=1;break;
case 0xef:P0=0xee;P2=0x77;a=0xfd;b=0x45;EA=1;break;
case 0xdf:P0=0xdd;P2=0xbb;a=0xfd;b=0x92;EA=1;break;
case 0xbf:P0=0xbb;P2=0xdd;a=0xfd;b=0xd0;EA=1;break;
case 0x7f:P0=0x77;P2=0xee;a=0xfd;b=0xee;EA=1;break;
default:EA=0;speaker=0;//P0=0xff;P2=0xff ;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void keyscan()
if(key1==0)
delay(5);
if(key1==0)
s1num++;
while(!key1);
if(s1num==1)
turn();
if(s1num==2)
back();
if(s1num==3)
qianhou();
if(s1num==4)
dangshuang();
if(s1num==5)
s1num=1;
if(key2==0)
delay(5);
while(~key2);
play1();
}[page]
void delay1(void)//第二个延时函数
uchar n=15;
while(n--)
uchar i;
for(i=0;i<125;i++);
void play1(void)//播放生日快乐
uchar m=0;
uchar s;
uchar c=1;
P0=0xaa;
P2=0x55;
while(1)
EA=0;
c=shengri_tone[m]; //取音符
s=shengri_beat[m]; //取节拍
a=yinfu[2*c-2];
b=yinfu[2*c-1];
EA=1;
while(s--)
delay1();
P0=~P0;
P2=~P2;
m++;
if(m>=33) return; //数值是shengri相关表中的元素数量
/*以下为N种流水灯流动花式*/
void turn()//流水灯顺时针走动(5次)
for(num1=0;num1<8;num1++)
for(num=0;num<8;num++)
P0=ledtable[num];
delay(30);//时间暂定
P0=0xff;//之后关闭P1组
for(num=7;num>-1;num--)
P2=ledtable2[num];
delay(30);
P2=0xff;//之后关闭P2组
void back()//逆时针流动
P2=ledtable[num];
delay(30);
P2=0xff;
P0=ledtable2[num];
delay(30);
P0=0xff;
void qianhou()//前后来回
for(num1=0;num1<10;num1++)
P0=ledtable[num];
P2=ledtable2[num];
delay(30);
P0=0xff;
P2=0xff;
P0=ledtable[num];
P2=ledtable2[num];
delay(30);
P0=0xff;
P2=0xff;
void dangshuang()//单数双数
for(num1=0;num1<15;num1++)
P0=0x55;
P2=0xaa;
delay(150);
P0=0xaa;
P2=0x55;
delay(150);
