Author: Made by Xura
Date: 2008.8.28
程序描述:利用Timer_A捕获脉冲宽度
利用MSP430单片机定时器A和捕获/比较功能模块结合使用,实现脉冲宽度的测量
程序用到了定时器A的CCI1A端口(MSP430F14X的P1.2引脚)作捕获外部输入
的脉冲电平跳变,start,end,两个个变量来计算脉冲宽度
#include "msp430x14x.h"
#include "lcd12864.h"
uint start,end;
uint width; //==用于存放脉宽==
uint period; //==用于存放周期==
uint frequency; //==用于存放频率==
uint fy[7]; //==用于存放频率显示数据==
uint pd[7]; //==用于存放周期显示数据==
uint wh[6]; //==用于存放脉宽显示数据==
const unsigned char zhouqi[]={"周期为:(us) "};
const unsigned char us[]={"us "};
const unsigned char pinlv[]={"频率为:(Hz) "};
const unsigned char hz[]={"HZ "};
void process(void); //==函数声明==
void delay(); //==延时函数==
void InitSys(); //==初始化时钟==
主函数
int main( void )
WDTCTL = WDTPW + WDTHOLD; //==关狗==
InitSys(); //==初始化时钟,SMCLK,MCLK均为8M==
P1DIR&=~BIT2;
P1SEL = BIT2; //==设置P1.2端口为功能模块使用,即:做捕获源==
TACTL = TASSEL_2+ID_3+TACLR+TAIE+MC1;//==定时器A时钟信号选择SMCLK,8分频,同时设置定时器A计数模式为连续增计模式==
CCTL1 = CM_1+SCS+CAP+CCIE; //==输入上升沿捕获,CCI0A为捕获信号源==
_EINT(); //==开全局中断允许==
Ini_Lcd(); //==初始化液晶==
Clear_GDRAM(); //==清屏==
Disp_HZ(0x80,zhouqi,8);
Disp_HZ(0x88,pinlv,8);
while(1)
process();
Write_Cmd(0x90);//==写地址==
Write_Data(0x30+pd[6]);
Write_Data(0x30+pd[5]);
Write_Data(0x30+pd[4]);
Write_Data(0x30+pd[3]);
Write_Data(0x30+pd[2]);
Write_Data(0x30+pd[1]);
Write_Data(0x30+pd[0]);
Write_Cmd(0x98);//==写地址==
Write_Data(0x30+fy[6]);
Write_Data(0x30+fy[5]);
Write_Data(0x30+fy[4]);
Write_Data(0x30+fy[3]);
Write_Data(0x30+fy[2]);
Write_Data(0x30+fy[1]);
Write_Data(0x30+fy[0]);
delay();
初始化时钟
void InitSys()
unsigned int i;
//--- 使用XT2振荡器 ---
BCSCTL1&=~XT2OFF; //==打开XT2振荡器==
do
IFG1 &= ~OFIFG; //==清除振荡器失效标志==
for (i = 0xFF; i > 0; i--); //==延时,等待XT2起振==
while ((IFG1 & OFIFG) != 0); //==判断XT2是否起振==
BCSCTL2 =SELM_2+SELS; //==选择MCLK、SMCLK为XT2,8M==
延时函数
void delay()
unsigned int i;
unsigned int j=10;
for(i=10;i>0;i--)
while(j--);
数据处理
void process(void)
while(end
width = end-start; //==实际脉冲宽度的计算==
period = 2* width;
frequency=1000000/period;
pd[6]=period/1000000;
pd[5]=(period-1000000*pd[6])/100000;
pd[4]=(period-1000000*pd[6]-100000*pd[5])/10000;
pd[3]=(period-1000000*pd[6]-100000*pd[5]-10000*pd[4])/1000;
pd[2]=(period-1000000*pd[6]-100000*pd[5]-10000*pd[4]-1000*pd[3])/100;
pd[1]=(period-1000000*pd[6]-100000*pd[5]-10000*pd[4]-1000*pd[3]-100*pd[2])/10;
pd[0]=period%10;
fy[6]=frequency/1000000;
fy[5]=(frequency-1000000*fy[6])/100000;
fy[4]=(frequency-1000000*fy[6]-100000*fy[5])/10000;
fy[3]=(frequency-1000000*fy[6]-100000*fy[5]-10000*fy[4])/1000;
fy[2]=(frequency-1000000*fy[6]-100000*fy[5]-10000*fy[4]-1000*fy[3])/100;
fy[1]=(frequency-1000000*fy[6]-100000*fy[5]-10000*fy[4]-1000*fy[3]-100*fy[2])/10;
fy[0]=frequency%10;
中断处理函数
#pragma vector=TIMERA1_VECTOR //==定时器A中断处理==
__interrupt void timer_a(void)
switch(TAIV) //==向量查询==
{ case 2: //==捕获中断==
if(CCTL1&CM0) //==捕获到上升沿==
CCTL1=(CCTL1&(~CM0))|CM1; //==更变设置为下降沿触发==
start=TAR; //==记录初始时间==
else if (CCTL1&CM1) //==捕获到下降沿==
CCTL1=(CCTL1&(~CM1))|CM0; //==更变设置为上升沿触发==
end=TAR; //==用start,end,overflow计算脉冲宽度==
break;
default:
break;
