先看代码
#include "stc12.h"
unsigned int Last_Capture_Data=0;
unsigned int New_Capture_Data=0;
unsigned int g_Period=0;
unsigned int g_Frequency=0;
unsigned char str1[12];
unsigned char str2[12];
bit Capture_over = 0;
sbit KEY_1 = P2^7;
extern void InitLcd1602();
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
void Delay50ms();
void PCA_Init (bit module);
void IntToString(unsigned char *str, unsigned int dat);
void main (void)
PCA_Init(0);
InitLcd1602();
P2 = 0xF7;
while(1)
if(!KEY_1)
Delay50ms();
if(!KEY_1)
while(!KEY_1);
CCAPM0 = 0x11;
CR = 1;
if(Capture_over)
Capture_over = 0;
// g_Frequency = (long)1000000 / g_Period;
g_Frequency = (long)11059200 / (g_Period * 12);
IntToString(str1, g_Period);
IntToString(str2, g_Frequency);
LcdShowStr(1, 0, "length:");
LcdShowStr(8, 0, str1);
LcdShowStr(1, 1, "freque:");
LcdShowStr(8, 1, str2);
//CIDL - - - CPS2 CPS1 CPS0 ECF
CMOD = 0x80;
//CF CR - - - - CCF1 CCF0
CCON = 0x00;
if (module == 0)
CCAPM0 = 0x10;
CCAP0L = 0x00;
CCAP0H = 0x00;
else
CCAPM1 = 0x11;
CCAP1L = 0x00;
CCAP1H = 0x00;
CL = 0x00;
CH = 0x00;
EA = 1;
//CR = 1;
unsigned char buf[12];
unsigned char i = 0;
do{
buf[i++] = dat % 10;
dat /= 10;
}while(dat > 0);
while(i-- > 0)
*str++ = buf[i] + '0';//数组转换成ASCII反向拷贝到字符串指针
*str = '\0';
void PCA_Int(void) interrupt 7
if (CCF0)
CCF0 = 0;
if(Last_Capture_Data == 0)
Last_Capture_Data = CCAP0H;
Last_Capture_Data = (Last_Capture_Data << 8) + CCAP0L;
else
New_Capture_Data = CCAP0H;
New_Capture_Data = (New_Capture_Data << 8) + CCAP0L;
g_Period = New_Capture_Data - Last_Capture_Data;
CR = 0;
CCAPM0 = 0x10;
CCAP0L = 0x00;
CCAP0H = 0x00;
CL = 0x00;
CH = 0x00;
Capture_over = 1;
void Delay50ms() //@11.0592MHz
unsigned char i, j, k;
i = 3;
j = 26;
k = 223;
do
do
while (--k);
} while (--j);
} while (--i);
配置流程:
CMOD 设置禁止溢出中断
设置CCAPMx设置开启捕获中断,以及上升沿捕获还是下降沿捕获
清零CCnPL、CCnPH以及CH、CL
其实最重要的还得看手册,介绍的真心很详细!!!
一个非常详细的电路图,分分享一下:
很明显,图的意思就是设置好上升沿捕获或者下降沿捕获后,由于CL、CH一直在走,一旦满足条件就把CL./CH的值分别装入CCAPL以及CCAPH中,如果此时使能PCA中断的话,会触发中断进入中断。
