嵌入式 > 技术百科 > 详情
IIC总线时序
发布时间:2020-06-16 发布时间:
最近做的项目中涉及了IIC总线的运用
IIC总线的运用范围十分广泛
写下博客记录
IIC总线延时 大于4.7us
#define Decoded_iic_delay() \
 Decoded_iic_DELAY_TMP=Decoded_iic_DELAY_VALUE;\
 while(--Decoded_iic_DELAY_TMP);\
初始化
void Decoded_iic_init()
 Decoded_iic_SCL=1;
 Decoded_iic_delay();
 Decoded_iic_SDA=1;
开始信号
void Decoded_iic_start()
 Decoded_iic_SDA=1;
 //Myputchar(Decoded_iic_SDA);
 Decoded_iic_SCL=1;
 //Myputchar(Decoded_iic_SCL);
 Decoded_iic_SDA=0;
 Decoded_iic_SCL=0;
写时序
void Decoded_iic_write(uchar dat)
 uchar idata t=8;
 while(t--)
  Decoded_iic_SDA=(bit)(dat&0x80);
  dat<<=1;
  Decoded_iic_SCL=1;
  Decoded_iic_SCL=0;
读时序
uchar Decoded_iic_read()
 uchar dat=0;
 uchar t=8;
 //Myputchar(dat);
 Decoded_iic_SDA=1;读之前SDA拉高
 while(t--)
  Decoded_iic_SCL=1;
  dat <<= 1;一定要先移位后读 如果先读后移位会挤掉最高位
  if(Decoded_iic_SDA)
   dat |= 0x01;
  Decoded_iic_SCL=0;
 return dat;
获取ACK
bit Decoded_iic_getack()
 bit ack;
 Decoded_iic_SDA=1;SDA为高释放总线
 Decoded_iic_SCL=1;
 ack=Decoded_iic_SDA;
 Decoded_iic_SCL=0;
 return ack;
发送ACK
void Decoded_iic_putack(bit ack)
 Decoded_iic_SDA=ack;
 Decoded_iic_SCL=1;
 Decoded_iic_SCL=0;
结束信号
void Decoded_iic_stop()
 uint t=Decoded_iic_WAIT_VALUE;
 Decoded_iic_SDA=0;
 Decoded_iic_SCL=1;
 Decoded_iic_SDA=1;
 while(t--);
综合发送
bit Decoded_iic_puts(unsigned char SlaveAddr,uchar *dat,unsigned int Length)
 if ( Length == 0 ) return 0;
 Decoded_iic_start();
 Decoded_iic_write(SlaveAddr);发送地址
 if ( Decoded_iic_getack() )
  Decoded_iic_stop();
  return 1;
发送数据
 do
  Decoded_iic_write(*dat++);
   //Myputchar('c');
    break;
 } while ( --Length != 0 );
 Decoded_iic_stop();
 if ( Length == 0 )
  //Myputchar('a');
  return 0;
 else
  //Myputchar('b');
  return 1;
综合接收数据
bit Decoded_iic_gets(unsigned char SlaveAddr,uchar *dat,unsigned int Length)
 if(!Length)
 return 0;
 Decoded_iic_write(SlaveAddr+1);发送地址+1  +1是读的意思
 if(Decoded_iic_getack())
  Decoded_iic_stop();
  return 1;
 for (;;)
  *dat++ = Decoded_iic_read();
  if ( --Length == 0 )
   Decoded_iic_putack(1);发送非ACK
   break;
  Decoded_iic_putack(0);发送ACK
//接收完毕,停止I2C总线,并返回结果
 Decoded_iic_stop();
 return 0;
无人机新突破:或将利用手机发射塔追踪无人机
