* 功能 : P1.0用来控制LED的亮灭,软件延时50000,来翻转P1.0 *
* MSP430F2274 *
* ----------------- VCC 3.0v *
* /|\ | XIN|- ___ *
* | | XOUT|- | *
* --|RST P1.2|-->LED-----| *
* +--key-->|P1.3 P1.1|-->LED-----| *
* |---key-->|P1.4 P1.0|-->LED-----| *
* GND *
* 作者 : Singel *
* 时间 : 2008-10-11 16:36:00 *
* 调试环境 : IAR For MSP430 Embedded Workbench v3.42A *
#include"msp430x22x4.h"
unsigned char keybuffer;
unsigned char scanflag;
unsigned char TEMP_KEY;
void Do_Without_PORT_Register( void )
P1IE = 0x00;
P1IFG = 0x00;
P1IE = 0x00;
void PORT_init( void )
P1DIR |= (BIT0+BIT1+BIT2);
P1OUT |= (BIT0+BIT1+BIT2);
P1DIR &=~ (BIT4+BIT3);
P1IES &=~ (BIT4+BIT3);
P1IE |= (BIT4+BIT3);
P1IFG &=~ (BIT4+BIT3);
void key_procss ( void )
TEMP_KEY = TEMP_KEY&0X18;
switch(TEMP_KEY)
case 0x10: P1OUT ^= BIT0+BIT1+BIT2;break;
case 0x08: P1OUT ^= BIT0+BIT1+BIT2;break;
void main( void )
WDTCTL = WDTPW + WDTHOLD;
BCSCTL1 = CALBC1_12MHZ;
DCOCTL = CALBC1_12MHZ;
Do_Without_PORT_Register();
PORT_init();
_BIS_SR(GIE+LPM4_bits);
while(1)
if(scanflag)
scanflag = 0;
key_procss();
_BIS_SR(GIE + LPM4_bits);
#pragma vector = PORT1_VECTOR
__interrupt void PORT1_ISR ( void )
_BIC_SR_IRQ(LPM4_bits);
TEMP_KEY = P1IFG;
scanflag = 1;
P1IE &=~ (BIT4+BIT3);
