嵌入式 > 技术百科 > 详情
STM8 can通讯
发布时间:2025-01-23 发布时间:
CAN通讯的速率,可以用示波器测试TX或RX,看最窄的波形,如果为16us,则为62500,如果为8us则是125000,我也搞不懂为什么STM8选内部时钟CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);  即16M
而CAN_Prescaler = 8;//8@125KHZ   16@62500HZ ,预分频选8时,是125KHZ,这是我量出的实际结果。
void CHECK_MAIL(void)//这个只是我调试中用于参考的,可以不检查直接发送
uchar i;
i=CAN_TransmitStatus(CAN_TxStatus_MailBox0Ok);
PRINTF("maiL0=%d ",&i);
i=CAN_TransmitStatus(CAN_TxStatus_MailBox1Ok);
PRINTF("maiL1=%d ",&i);
i=CAN_TransmitStatus(CAN_TxStatus_MailBox2Ok);
PRINTF("maiL2=%d \r\n",&i);
extern __IO uint8_t _Data[8];
extern char b_can_rxon;
void main(void)
uint16_t tx_count=0;
uint16_t re_tx=0;
 CAN_TxStatus_TypeDef status = CAN_TxStatus_Failed;
 CAN_Id_TypeDef Tx_IDE ;//CAN_Id_Standard;  //= CAN_Id_Extended
 CAN_RTR_TypeDef Tx_RTR = CAN_RTR_Data;
 uint8_t Tx_DLC = 0;
 uint8_t Tx_Data[8] = {0};
 uint32_t Tx_Id = 0;
 CLK_Config();
 UART_CONFIG();
//  GPIO_Config();
 // LCD_Config();
 CAN_Config();
 enableInterrupts();
PRINTF("hello world!~\r\n",NULL);
GPIO_Init(GPIOC, GPIO_PIN_1,GPIO_MODE_OUT_PP_HIGH_FAST);
 while(1)
  #if 1
 //PRINTF("hello world!~\r\n",NULL);
//Delay(1000);
tx_count++;
if(b_can_rxon)
GPIO_WriteReverse(GPIOC,GPIO_PIN_1);
PRINTF("RX:%d\r\n",&_Data[0]);
b_can_rxon=0;
#else
   Delay(500);
   Tx_Id = 0x12345678;//29bit
   Tx_IDE = CAN_Id_Extended;//CAN_Id_Standard;
   Tx_DLC = 2;
   Tx_Data[0] = tx_count++;
   Tx_Data[1] = ~Tx_Data[0];
 CHECK_MAIL();
   status = CAN_Transmit(Tx_Id,Tx_IDE,Tx_RTR,Tx_DLC,Tx_Data);
 if(status>0x10){PRINTF(" error:%d\r\n",&status);continue;}//CAN_TxStatus_Ok
 while(CAN_TransmitStatus(status)!=CAN_TxStatus_Ok)
 {if(++re_tx==0)break;
 if(re_tx==0)
 if(status==CAN_TxStatus_MailBox0Ok)  CAN_ClearFlag(CAN_FLAG_RQCP0);
 if(status==CAN_TxStatus_MailBox1Ok)  CAN_ClearFlag(CAN_FLAG_RQCP1);
 if(status==CAN_TxStatus_MailBox2Ok)  CAN_ClearFlag(CAN_FLAG_RQCP2);
 PRINTF(" 强制CLEAR mail=%d\r\n",&status);//CAN_TxStatus_Ok
 else
 PRINTF("tx:success mail=%d\r\n",&status);//CAN_TxStatus_Ok
   #endif
void CLK_Config(void)
void CAN_Config(void)
 CAN_InitStatus_TypeDef status = CAN_InitStatus_Failed;
 CAN_FilterNumber_TypeDef CAN_FilterNumber;
 FunctionalState CAN_FilterActivation;
 CAN_FilterMode_TypeDef CAN_FilterMode;
 CAN_FilterScale_TypeDef CAN_FilterScale;
 uint8_t CAN_FilterID1;
 uint8_t CAN_FilterID2;
 uint8_t CAN_FilterID3;
 uint8_t CAN_FilterID4;
 uint8_t CAN_FilterIDMask1;
 uint8_t CAN_FilterIDMask2;
 uint8_t CAN_FilterIDMask3;
 uint8_t CAN_FilterIDMask4;
 CAN_MasterCtrl_TypeDef CAN_MasterCtrl;
 CAN_Mode_TypeDef CAN_Mode;
 CAN_SynJumpWidth_TypeDef CAN_SynJumpWidth;
 CAN_BitSeg1_TypeDef CAN_BitSeg1;
 CAN_BitSeg2_TypeDef CAN_BitSeg2;
 uint8_t CAN_Prescaler;
 CAN_DeInit();
 CAN_MasterCtrl=CAN_MasterCtrl_AllDisabled;
 CAN_Mode = CAN_Mode_Normal;
 CAN_SynJumpWidth = CAN_SynJumpWidth_1TimeQuantum;
 CAN_BitSeg1 = CAN_BitSeg1_8TimeQuantum;
 CAN_BitSeg2 = CAN_BitSeg2_7TimeQuantum;
 status = CAN_Init(CAN_MasterCtrl, CAN_Mode, CAN_SynJumpWidth, CAN_BitSeg1, \
          CAN_BitSeg2, CAN_Prescaler);
 CAN_FilterNumber = CAN_FilterNumber_0;
 CAN_FilterActivation = ENABLE;
 CAN_FilterMode = CAN_FilterMode_IdMask;
 CAN_FilterScale = CAN_FilterScale_32Bit;
 CAN_FilterID1=0x91;
 CAN_FilterID2=0x00;
 CAN_FilterID3=0x00;
 CAN_FilterID4=0x00;
 CAN_FilterIDMask1=0xff;
 CAN_FilterIDMask2=0;
 CAN_FilterIDMask3=0;
 CAN_FilterIDMask4=0;
 CAN_FilterInit(CAN_FilterNumber, CAN_FilterActivation, CAN_FilterMode,
         CAN_FilterScale,CAN_FilterID1, CAN_FilterID2, CAN_FilterID3,
         CAN_FilterID4,CAN_FilterIDMask1, CAN_FilterIDMask2,
         CAN_FilterIDMask3, CAN_FilterIDMask4);
 CAN_ITConfig(CAN_IT_FMP, ENABLE);
浅谈IP技术在网络电视中的应用
