上面是电路原理图
下面是程序源代码:
功能描述:运用定时器T0实现电子时钟
#include"reg52.h"
#include"intrins.h"
#define uint unsigned int
#define uchar unsigned char
sbit p32=P3^2;
sbit p33=P3^3;
uchar num;
uint number,number0,number1;
uchar code table[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40};
void tiaoz();
void delay()
uint b;
for(b=300;b>0;b--);
void time() interrupt 1
TH0=(65536-45872)/256;
TL0=(65536-45872)%256;
num++;
//tiaoz();
//以下屏蔽内容为 利用两个外部中断来调整“时,分”
/*void tiaof() interrupt 0 //分针调整
if(p32==0)
delay();
if(p32==0)
number=0;
number0++;
while(!p32);
if(number0>=60)
number0=0;
void tiaos() interrupt 2 //时针调整
if(p33==0)
delay();
if(p33==0)
number=0;
number1++;
while(!p33);
if(number1>=24)
number1=0;
//运用独立按键来调整“时,分”
void tiaoz0()
if(p32==0)
delay();
if(p32==0)
number=0;
number0++;
while(!p32);
if(number0>=60)
number0=0;
if(p33==0)
delay();
if(p33==0)
number=0;
number1++;
while(!p33);
if(number1>=24)
number1=0;
