//输出PWM波形驱动发光二极管,亮度由暗到灭,呈闪烁状态
//样值采取正弦波公式,示例如下
//正弦波采样值计算公式
// f(x)=128+127*sin(2*3.1415*x/127) x=[0....127]
//PWM输出也可通过控制LED发光来直观的看到效果,亮度持续的变化
//可以通过选跳线帽选择是通过LED直接查看还是通过滤波器查看实际波形
//编译环境 AVR Studio 4.17/AVR GCC
//系统时钟7.3728MHZ,设置熔丝位为外部高频石英晶体振荡,启动时间4.1ms
//包含文件
#include
#include
#define F_CPU7372800// 单片机主频为7.3728MHz,用于延时子程序
#include
#include
#include
#include //中断信号头文件
//定义变量区
#define f_count 254 //0CR0寄存器初始值
#define timer_clk 0x07
#define delay_us(x) _delay_us(x) //AVR GCC延时函数 x(us)
#define delay_ms(x) _delay_ms(x) //AVR GCC延时函数 x(ms)
#define uchar unsigned char
#define uint unsigned int
#define ulong unsigned long
uchar auc_SinParam[128] = {
128,134,140,147,153,159,165,171,177,182,188,193,198,204,208,213,
218,222,226,230,233,237,240,242,245,247,249,251,252,253,254,254,
254,254,253,252,251,250,248,246,244,241,238,235,232,228,224,220,
215,211,206,201,196,191,185,179,174,168,162,156,150,144,137,131,
125,119,112,106,100,94,88,82,77,71,65,60,55,50,45,41,
36,32,28,24,21,18,15,12,10,8,6,5,4,3,2,2,
2,2,3,4,5,7,9,11,14,16,19,23,26,30,34,38,
43,48,52,57,63,68,74,79,85,91,97,103,109,116,122,128}; // 128点正弦波样本值
uchar x_SW = 8,X_LUT = 0;
//初始化子程序
void system_init() //IO口初始化
PORTB=0xff; //PB设置为输出
DDRB=0xff; //上拉电阻无效
void timer0_init() //定时器初始化
TCCR0=0x68|timer_clk; //快读PWM模式,OC0输出,分频
OCR0=128; //OCR0比较匹配寄存器值
TIFR=0x01; //清中断标志位
TIMSK=0x01; //使能定时器0溢出中断
//定时器0中断服务子程序
ISR(TIMER0_OVF_vect) //中断服务程序
X_LUT += x_SW; // 新样点指针
if (X_LUT > 127) X_LUT -= 128; // 样点指针调整
OCR0 =auc_SinParam[X_LUT]; // 取样点指针到比较匹配寄存器
//主程序
int main(void)
system_init(); //系统初始化.PB3输出PWM波形
timer0_init(); //定时器0初始化,完成PWM相关配置
SREG|=0x80; //开启全局中断
while(1)
