嵌入式 > 嵌入式开发 > 详情
s3c2440头文件之2440lib.h
发布时间:2020-07-08 发布时间:
// File Name : 2440lib.h
// Function : S3C2440
// Date : February 26, 2002
// Version : 0.0
// History
// 0.0 :Feb.20.2002:SOP : Programming start
// 0.01:Mar.29.2002:purnnamu: For Sleep_wake_up, the START... label is added
#ifndef __2440lib_h__
#define __2440lib_h__
#ifdef __cplusplus
extern "C" {
#endif
#include "option.h"
#if USE_MAIN
#include
#define Uart_Printf printf
#endif
#define min(x1,x2) (((x1)#define max(x1,x2) (((x1)>(x2))? (x1):(x2))
#define ONESEC0 (62500) //16us resolution, max 1.04 sec
#define ONESEC1 (31250) //32us resolution, max 2.09 sec
#define ONESEC2 (15625) //64us resolution, max 4.19 sec
#define ONESEC3 (7812) //128us resolution, max 8.38 sec
#define ONESEC4 (PCLK/128/(0xff+1))//@60Mhz, 128*4us resolution, max 32.53 sec
#define NULL 0
#define EnterPWDN(clkcon) ((void (*)(int))0x20)(clkcon)
void StartPointAfterSleepWakeUp(void); //purnnamu:Mar.29.2002
// 2440lib.c
void Delay(int time); //Watchdog Timer is used.
void *malloc(unsigned nbyte);
void free(void *pt);
void Port_Init(void);
void Uart_Select(int ch);
void Uart_TxEmpty(int ch);
void Uart_Init(int mclk,int baud);
char Uart_Getch(void);
char Uart_GetKey(void);
void Uart_SendByte(int data);
#if !USE_MAIN
void Uart_Printf(const char *fmt,...);
#endif
void Uart_SendString(char *pt);
void Timer_Start(int divider); //Watchdog Timer is used.
int Timer_Stop(void); //Watchdog Timer is used.
void ChangeClockDivider(int hdivn_val,int pdivn_val);
void ChangeUPllValue(int m,int p,int s);
void ChangeMPllValue(int m,int p,int s);
#ifdef __cplusplus
#endif
#endif //__2440lib_h__
基于嵌入式系统的CAN总线网络通信流程设计
