/* SD Code for M32L */
/* By pasyong */
/* 2006-4 */
/* Base ICC6.31A */
#include
#include
#include "1011.h"
#define uchar unsigned char
#define uint unsigned int
#define MMC_CS_PIN BIT(4) //PORTB.4
#define MMC_PORT PORTB
uchar reading=0,a=0,pointer=0;
void sd_port_init()
MMC_PORT|=MMC_CS_PIN;
uchar BUFFER[512]; //扇区缓冲区
uint i=0;
void delay_nus(uint n)
unsigned char b;
for (b = 1; b
//Send a Command to MMC/SD-Card
//Return: the second byte of response register of MMC/SD-Card
uchar SD_Write_Command(uchar cmd,unsigned long arg)
uchar tmp;
uchar retry=0;
//MMC_PORT|=MMC_CS_PIN; //SD卡关闭
//send 8 Clock Impulse
Write_Byte_SPI(0xFF);
//set MMC_Chip_Select to low (MMC/SD-Card active)
MMC_PORT&=~MMC_CS_PIN; //SD卡使能
Write_Byte_SPI(cmd|0x40); //送头命令
Write_Byte_SPI(arg>>24);
Write_Byte_SPI(arg>>16); //send 6 Byte Command to MMC/SD-Card
Write_Byte_SPI(arg>>8);
Write_Byte_SPI(arg&0xff);
Write_Byte_SPI(0x95); //仅仅对RESET有效的CRC效验码
//get 8 bit response
//Read_Byte_MMC(); //read the first byte,ignore it.
do
{ //Only last 8 bit is used here.Read it out.
tmp = Read_Byte_SPI();
retry++;
while((tmp==0xff)&&(retry<100)); //当没有收到有效的命令的时候
if(reading==0)
MMC_PORT|=MMC_CS_PIN; //MMC_CS_PIN=1;
else MMC_PORT&=~MMC_CS_PIN; //MMC_CS_PIN=0;
return(tmp);
//SD卡初始化(SPI-MODE)
uchar SD_Init(void)
uchar retry,temp;
uchar i;
delay_nus(250); //Wait MMC/SD ready...
for (i=0;i<0x0f;i++)
Write_Byte_SPI(0xff); //send 74 clock at least!!!
//Send Command CMD0 to MMC/SD Card
retry=0;
do
{ //retry 200 times to send CMD0 command
temp=SD_Write_Command(0,0);
retry++;
if(retry==100)
;//CMD0 Error!
while(temp!=1);
//Send Command CMD1 to MMC/SD-Card
retry=0;
do
{ //retry 100 times to send CMD1 command
temp=SD_Write_Command(1,0);
retry++;
if(retry==100)
while(temp!=0);
retry=0;
SD_Write_Command(16,512); //设置一次读写BLOCK的长度为512个字节
MMC_PORT|=MMC_CS_PIN; //MMC_CS_PIN=1; //set MMC_Chip_Select to high
return(0); //All commands have been taken.
//从SD卡读一个扇区 Return 0 if no Error.
uchar SD_Read_Block(unsigned long address)
uchar temp=0;uint i=0;
reading=1;
temp=SD_Write_Command(17,address); //读出RESPONSE
while (Read_Byte_SPI()!= 0xfe)
{;} //直到读取到了数据的开始头0XFE,才继续
for(i=0; i<512; i++)
BUFFER[i]=Read_Byte_SPI();
Read_Byte_SPI();//CRC - Byte
reading=0;
MMC_PORT|=MMC_CS_PIN; //关闭SD卡
return(temp);
