#include
#include
sbit SCLK=P3^6;
sbit SDA=P3^4;
sbit RST = P3^5;
//unsigned char code Write_Address[]={0x80,0x82,0x84};
unsigned char code Read_Address[]={0x85,0x83,0x81};
unsigned char Time_Table[3];
void Write_Byte(unsigned char Data)//写一个字节: 地址或数据
unsigned char i;
for(i=0; i<8; i++)
SCLK=0;
SDA=Data&0x01;
Data=Data>>1;
SCLK=1;
void Write_RTC(unsigned char Address, unsigned char Data)
RST=0;
_nop_();
SCLK=0;
_nop_();
RST=1;
Write_Byte(Address);
Write_Byte(Data);
RST=0;
unsigned char Read_Byte() //读一个字节: 数据
unsigned char Data=0;
unsigned char i;
for(i=0; i<8; i++)
if(SDA==1)
Data=Data|0x80;
SCLK=0;
Data=Data>>1;
_nop_();
SCLK=1;
return Data;
unsigned char Read_RTC(unsigned char Address) //
unsigned char Data1,Data2;
RST=0;
_nop_();
SCLK=0;
_nop_();
RST=1;
Data=Read_Byte();
RST=0;
Data1=Data/16;
Data2=Data%16;
Data=Data2+Data1*10;
return Data;
void Init_RTC() //初始化实时 时钟表RTC
Write_RTC(0x8e, 0x00);
Write_RTC(0x80, 0x56);
Write_RTC(0x82, 0x48);
Write_RTC(0x84, 0x12);
Write_RTC(0x8e, 0x80)
void DisplayTime() //把时间显示1602液晶
unsigned char i;
InitLCD();
Write_Command(0x80+0x03);
for(i=0; i<3; i++)
Time_Table[i]=Read_RTC(Read_Address[i]);
Write_Data(0x30+Time_Table[i]/10);
Write_Data(0x30+Time_Table[i]%10);
if(i!=2)
Write_Data(:);
void main()
Init_RTC();
DisplayTime();
while(1);
其实,写这个程序,也是比较简单的, 比在24C02 芯片里读写容易了。因为在24C02读写里,是使用I2C总线传输数据的,关键要把握好时序读写,至今仍然未解决这个24C02芯片的读写,也不知道是,芯片出问题,还是自己程序的时序出问题。
