#includereg52.h>
sbit KEY1 = P3^1; //定义调速按键
sbit PWM = P1^5; //定义调速端口
unsigned char CYCLE; //定义周期T=x*0.1ms
unsigned char PWM_ON ; //定义高电平时间
void delay(unsigned int cnt)
while(--cnt);
main()
unsigned char PWM_Num;
TMOD |=0x01;
TH0=(65536-1000)/256;
TL0=(65536-1000)%256;
IE= 0x82;
TR0=1;
CYCLE = 10;
while(1)
if(!KEY1)
delay(10000);
if(!KEY1)
PWM_Num++;
if(PWM_Num==4)
PWM_Num=0;
switch(PWM_Num)
case 0:P0=0x06;PWM_ON=0;break;
case 1:P0=0x5B;PWM_ON=4;break;
case 2:P0=0x4F;PWM_ON=6;break;
case 3:P0=0x66;PWM_ON=8;break;
default:break;
void tim(void) interrupt 1 using 1
static unsigned char count;
if (count==PWM_ON)
PWM = 1;
count++;
if(count == CYCLE)
count=0;
if(PWM_ON!=0)
PWM = 0;
