此程序在STC89C52上实验通过!
晶振11.05926,
占用资源,外部中断1,
LCD1602,显示解码!
串口通讯波特率4800KBS;
提示,在中端中不可以用while(p3_2);
否则,不能顺利跳出终端!
#include AT89X52.H>
#include LCD.h
#define uchar unsigned char
#define uint unsigned int
//void Delay(unsigned int i);
void chuangkou(void);
void unint0 (void);
void senddata(unsigned char outdata);
unsigned char yandata[]=
'0',
'1',
'2',
'3',
'4',
'5',
'6',
'7',
'8',
'9',
'A',
'B',
'C',
'D',
'E',
'F'
unsigned char Iid[4]={0,0,0,0};
void main(void)
LCD1602();
Init_Lcd();
unint0();
chuangkou();
P3_2=1;
senddata('1');
while(1)
Display_LCD_Byte(0,0,'I');
Display_LCD_Byte(0,1,'D');
Display_LCD_Byte(0,2,':');
Display_LCD_Byte(0,5,'0');
Display_LCD_Byte(0,6,'X');
Display_LCD_Byte(0,7,yandata[ Iid[0] / 16] );
Display_LCD_Byte(0,8,yandata[ Iid[0] % 16] );
Display_LCD_Byte(1,0,'D');
Display_LCD_Byte(1,1,'A');
Display_LCD_Byte(1,2,'T');
Display_LCD_Byte(1,3,'A');
Display_LCD_Byte(1,4,':');
Display_LCD_Byte(1,5,'0');
Display_LCD_Byte(1,6,'X');
Display_LCD_Byte(1,7,yandata[ Iid[2] / 16] );
Display_LCD_Byte(1,8,yandata[ Iid[2] % 16] );
/*void Delay(unsigned int i)
while(-- i);
TMOD = 0X20;// JI SHU QI 1
TH1=0XFA; //11.0592, 4800KPS
TL1 =0XFA;
TR1=1; //QI DONG
SCON=0X50; //
PCON=0X00; //BU JIA BEI
void unint0 (void)
EA=1;
EX0=1;
IT0=1;
SBUF=outdata;
while(!TI);
TI=0;
void INT_0() interrupt 0 using 1
unsigned char id[4]={0,0,0,0};
unsigned char cishu0,cishu1,cishu2;
EX0=0;
for(cishu0=0;cishu010;cishu0++)
Delay(100);
if(P3_2) goto exit;
if(!P3_2)
Delay(534);
while(!P3_2);//等待高电平 gou qu
for(cishu1=0;cishu1 4 ; cishu1 ++)
for(cishu2=0;cishu2 8 ; cishu2 ++)
while(!P3_2);//等待该gao电平开始延时,判断高低
Delay(90);
if(P3_2)
id[cishu1]|= 0x01 cishu2;
Delay(100);
//while(P3_2);在解码时千万不要有这样的口令
/* else
id[cishu1]= 0xfe cishu2;
if(id[0]!=~id[1]) goto exit;
if(id[0]!=0x02) goto exit;
if(id[2]!=~id[3]) goto exit;
senddata(id[0]);
// senddata(id[1]);
senddata(id[2]);//数据码
// senddata(id[3]);//数据码饭吗
for(cishu0=0;cishu0200;cishu0++)
P2_0=~P2_0;
Delay(50);
Iid[0]=id[0];
Iid[2]=id[2];
exit:
// while(!P3_2);
EX0=1;
