// Design Name : uart
// File Name : uart.v
// Function : Simple UART
// Coder : Deepak Kumar Tala
module uart (
reset ,
txclk ,
ld_tx_data ,
tx_data ,
tx_enable ,
tx_out ,
tx_empty ,
rxclk ,
uld_rx_data ,
rx_data ,
rx_enable ,
rx_in ,
rx_empty
// Port declarations
input reset ;
input txclk ;
input ld_tx_data ;
input [7:0] tx_data ;
input tx_enable ;
output tx_out ;
output tx_empty ;
input rxclk ;
input uld_rx_data ;
output [7:0] rx_data ;
input rx_enable ;
input rx_in ;
output rx_empty ;
// Internal Variables
reg [7:0] tx_reg ;
reg tx_empty ;
reg tx_over_run ;
reg [3:0] tx_cnt ;
reg tx_out ;
reg [7:0] rx_reg ;
reg [7:0] rx_data ;
reg [3:0] rx_sample_cnt ;
reg [3:0] rx_cnt ;
reg rx_frame_err ;
reg rx_over_run ;
reg rx_empty ;
reg rx_d1 ;
reg rx_d2 ;
reg rx_busy ;
// UART RX Logic
always @ (posedge rxclk or posedge reset)
if (reset) begin
rx_reg = 0;
rx_data = 0;
rx_sample_cnt = 0;
rx_cnt = 0;
rx_frame_err = 0;
rx_over_run = 0;
rx_empty = 1;
rx_d1 = 1;
rx_d2 = 1;
rx_busy = 0;
end else begin
// Synchronize the asynch signal
rx_d1 = rx_in;
rx_d2 = rx_d1;
// Uload the rx data
if (uld_rx_data) begin
rx_data = rx_reg;
rx_empty = 1;
end
// Receive data only when rx is enabled
if (rx_enable) begin
// Check if just received start of frame
