Linux中没有rc.local文件的解决方法是什么呢?这应该是很多工程师比较头疼的问题,下面就给大家例举几个解决办法。
比较新的Linux发行版已经没有rc.local文件了。因为已经将其服务化了。
解决方法:
1、设置rc-local.service
sudo vim /etc/systemd/system/rc-local.service
[Unit]
Deion=/etc/rc.local Compatibility
ConditionPathExists=/etc/rc.local
[Service]
Type=forking
ExecStart=/etc/rc.local start
TimeoutSec=0
StandardOutput=tty
RemainAfterExit=yes
SysVStartPriority=99
[Install]
WantedBy=multi-user.target
2、激活rc-local.service
sudo systemctl enable rc-local.service
3、添加启动服务
手工创建或者拷贝已有的/etc/rc.local,并赋予执行权限
#!/bin/sh -e
# rc.local
# This is executed at the end of each multiuser runlevel.
# Make sure that the will “exit 0” on success or any other
# value on error.
# In order to enable or disable this just change the execution
# bits.
# By default this does nothing.
# 下面这条是要开机启动的命令
/home/selfcs/anaconda3/bin/Python /home/selfcs/t.py 》 /home/selfcs/auto.log
exit 0
#给予脚本执行权限
sudo chmod +x /etc/rc.local
