#include
#define uchar unsigned char
void lcd_ini();
void ascii_change(void);
void delay();
void wri_add(uchar com);
void wri_dat(uchar com1);
void shan(void);
void disp();
void tkey(void);
sbit cs=P1^7;
sbit sid=P1^6;
sbit sclk=P1^5;
bit flag=1;
uchar dat,count,f=1;//f测试哪个单元为当前闪烁状态
uchar data clock[3]={23,45,12};
uchar code clockname[10]={"北京时间:"};
uchar data num[6];
void main()
lcd_ini();
count=10;//机器周期为1us,每次定时50ms,此变量用来控制循环次数,在下面赋值为20,共定时1秒
TMOD=0x01;
TL0=0XB0;
TH0=0X3C;
EA=1;
ET0=1;
IT0=1;
EX0=1;
TR0=1;
while(1)
back:ascii_change();
disp();
delay();
if(flag==1)
goto back;
tkey();
shan();
delay();
void lcd_ini()
wri_add(0x30);
delay();
wri_add(0x0c);
delay();
wri_add(0x01);
delay();
wri_add(0x06);
delay();
void timer1() interrupt 1 using 2
TL0=0XB0;
TH0=0X3C;
count--;
if(count==0)
count=10;
clock[2]++;//秒//
else
goto out;
if(clock[2]==60)
clock[2]=0;
clock[1]++;//分//
if(clock[1]==60)
clock[1]=0;
clock[0]++;
if(clock[0]==24)//时//
clock[0]=0;
out:_nop_();
num[5]=clock[2]-(clock[2]/10)*10+0x30;
num[4]=clock[2]/10+0x30;
num[3]=clock[1]-(clock[1]/10)*10+0x30;
num[2]=clock[1]/10+0x30;
num[1]=clock[0]-(clock[0]/10)*10+0x30;
num[0]=clock[0]/10+0x30;
void delay()
uchar i,j;
for (i=250;i>0;i--)
for (j=250;j>0;j--);
uchar i,j,k;
cs=0;
cs=1;
dat=0xf8;
for(i=1;i<=8;i++)
sid=(bit)(dat&0x80);
sclk=0;
sclk=1;
sclk=0;
dat=dat<<1;
dat=com;
dat=dat&0xf0;
for(j=1;j<=8;j++)
sclk=0;
sclk=1;
sclk=0;
dat=dat<<1;
dat=com;
dat=_cror_(dat,4);// 此为高低四位交换
dat=dat&0xf0;
for(k=1;k<=8;k++)
sclk=0;
sclk=1;
sclk=0;
dat=dat<<1;
uchar i,j,k;
cs=0;
cs=1;
dat=0xfa;
for(i=1;i<=8;i++)
sclk=0;
sclk=1;
sclk=0;
dat=dat<<1;
dat=com1;
dat=dat&0xf0;
for(j=1;j<=8;j++)
sclk=0;
sclk=1;
sclk=0;
dat=dat<<1;
dat=com1;
dat=dat&0xf0;
for(k=1;k<=8;k++)
sclk=0;
sclk=1;
sclk=0;
dat=dat<<1;
void disp()
uchar i,k=0;
wri_add(0x80);
for (i=1;i<=9;i++)
wri_dat(clockname[i-1]);
wri_add(0x90);
for (i=1;i<=6;i++)
k++;
if(k==3||k==5)
wri_dat(clockname[8]);//时间之间的冒号。
wri_dat(num[i-1]);
void shan(void)
uchar i,k=0;
wri_add(0x90);
if(f==1)
num[0]= ;
num[1]= ;
else
goto next;
for (i=1;i<=6;i++)
k++;
if(k==3||k==5)
wri_dat(num[i-1]);
goto return1;
next: if(f==2)
num[2]= ;
num[3]= ;
else
goto next1;
for (i=1;i<=6;i++)
k++;
if(k==3||k==5)
wri_dat(num[i-1]);
goto return1;
next1: if(f==3)
num[4]= ;
num[5]= ;
else
goto return1;
for (i=1;i<=6;i++)
k++;
if(k==3||k==5)
wri_dat(num[i-1]);
return1:_nop_();
void intr0() interrupt 0 using 2
flag=~flag;//判断是否闪烁位//
TR0=~TR0; //闪关定时否则开定时
f=1;
void tkey(void)
uchar judcekey;
judcekey=P1&0x0f;
if(judcekey==0x0f)
goto return2;
if (judcekey==0x0e)
f++;
if (f==4)
f=1;
if(judcekey==0x0d)
{clock[f-1]++;}
if (f==1)
{ if (clock[f-1]==24){
clock[f-1]=0;}
else{ if (clock[f-1]==60)
clock[f-1]=0;
if(judcekey==0x0b)
{clock[f-1]--;}
if (f==1)
{ if (clock[f-1]==0xff){
clock[f-1]=23;}
else
clock[f-1]=59;
return2:_nop_();
