//文件名: LCD.h (LCD头文件) *
#include "C8051F340.h"
#include
#define uint unsigned int
#define uchar unsigned char
//sbit e1 = P2^2; //up input enable;
sbit e2 = P2^2; //down input enable;
sbit rs = P2^0; //H=data; L=command;
//sbit rst= P3^0; //Reset Signal 低电平有效
void init_lcd ();
void clrram ();
void string_disp (uchar up,uchar down,uchar addr,uchar length,uchar code *pp); //显示字符串
void number_disp (uchar up,uchar down,uchar addr,uchar length,uchar number1,uchar number2); //显示数字
//up:上半屏 down:下半屏
//up为1,控制上半屏,down为1,控制下半屏
uchar Math_Subwith(uchar dat) //线序反转
uchar i,temp;
temp = 0x00;
for(i=0;i<8;i++)
temp >>= 1;
if((dat< {
temp |= 0x80;
else
temp &= 0x7F;
return temp;
//判忙
void chk_busy (uchar up,uchar down)
if(up==1)
P1 = Math_Subwith(0xff);
rs=0;
rw=1;
//e1=1;
P4 = P4|0x01;
while(P1 & 0x01);
//e1=0;
_nop_();_nop_();_nop_();_nop_();
P4 = P4&0xfe;
if(down==1)
P1 =Math_Subwith(0xff);
rs=0;
rw=1;
e2=1;
while(P1& 0x01);
e2=0;
//写命令
void send_c (uchar up,uchar down,uchar comm)
chk_busy (up,down);
rs=0; //command
rw=0; //write
if(up==1)
P1 = Math_Subwith(comm); //output comm
//e1=1;
P4 = P4|0x01;
_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
//e1=0;
P4 = P4&0xfe;
if(down==1)
e2=1;
e2=0;
