这个用的是 LSE (片外低速时钟)配合 掉电寄存器来确定是否配置时钟。
注释很全 话不多说了。
u8 TimeDisplay;
int main(void)
SystemInit();
stm32_Init ();//GPIO PA8 Init
USART_Configuration();//USART2 9600-8-N-1
NVIC_Configuration();//Enable the RTC Interrupt
RTC_Configuration();//RTC的启动
start_rct();//检测是否配置时钟
Time_Show();//不断地时钟串口输出
void LEDToggle(void)
GPIOA->ODR=GPIOA->ODR^GPIO_Pin_8 ;
RTC.C///////////////////////////////////////////////////////////////////////////////
#include "stm32f10x.h"
#include
u32 Time_Regulate(void);
void Time_Adjust(void);
void Time_Show(void);
void Time_Display(u32 TimeVar);
u32 USART_Scanf(u32 value);
extern u8 TimeDisplay;
void RTC_Configuration(void)
/* Enable PWR and BKP clocks */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR | RCC_APB1Periph_BKP, ENABLE);
/* Allow access to BKP Domain */
PWR_BackupAccessCmd(ENABLE);
/* Reset Backup Domain */
//BKP_DeInit(); //记录0XA5A5 来确定是否重置时间
/* Enable LSE */
RCC_LSEConfig(RCC_LSE_ON);
/* Wait till LSE is ready */
while (RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET)
/* Select LSE as RTC Clock Source */
RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
/* Enable RTC Clock */
RCC_RTCCLKCmd(ENABLE);
/* Wait for RTC registers synchronization */
RTC_WaitForSynchro();
/* Wait until last write operation on RTC registers has finished */
RTC_WaitForLastTask();
/* Enable the RTC Second */
RTC_ITConfig(RTC_IT_SEC, ENABLE);
/* Set RTC prescaler: set RTC period to 1sec */
RTC_SetPrescaler(32767); /* RTC period = RTCCLK/RTC_PR = (32.768 KHz)/(32767+1) */
* Function Name : Time_Regulate
* Description : Returns the time entered by user, using Hyperterminal.
* Input : None
* Output : None
* Return : Current time RTC counter value
//u32 Month_Days[13] = {0,31,28,31,30, 31, 30, 31, 31, 30, 31, 30, 31};
u32 Month_Days_Accu_C[13] = {0,31,59,90,120,151,181,212,243,273,304,334,365};
u32 Month_Days_Accu_L[13] = {0,31,60,91,121,152,182,213,244,274,305,335,366};
#define SecsPerDay (3600*24)
#if 1
u32 Tmp_Year=0xFFFF, Tmp_Month=0xFF, Tmp_Date=0xFF;
u32 LeapY, ComY, TotSeconds, TotDays;
#endif
u32 Tmp_HH = 0xFF, Tmp_MM = 0xFF, Tmp_SS = 0xFF;
printf("\r\n==============Time Settings=====================================");
#if 1
printf("\r\n Please Set Year");
while(Tmp_Year == 0xFFFF)
/*32-bit counter at Second Unit--> 4*1024*1024(s) --> 49710(day) --> 136(year)*/
Tmp_Year = USART_Scanf(2136);
printf(": %d", Tmp_Year);
printf("\r\n Please Set Month");
while(Tmp_Month == 0xFF)
Tmp_Month = USART_Scanf(12);
printf(": %d", Tmp_Month);
printf("\r\n Please Set Date");
while(Tmp_Date == 0xFF)
Tmp_Date = USART_Scanf(31);
printf(": %d", Tmp_Date);
#endif
printf("\r\n Please Set Hours");
while(Tmp_HH == 0xFF)
Tmp_HH = USART_Scanf(23);
printf(": %d", Tmp_HH);
printf("\r\n Please Set Minutes");
while(Tmp_MM == 0xFF)
Tmp_MM = USART_Scanf(59);
printf(": %d", Tmp_MM);;
printf("\r\n Please Set Seconds");
while(Tmp_SS == 0xFF)
Tmp_SS = USART_Scanf(59);
printf(": %d", Tmp_SS);
#if 1
/* change Year-Month-Data-Hour-Minute-Seconds into X(Second) to set RTC->CNTR */
if(Tmp_Year==2000)
LeapY = 0;
else
LeapY = (Tmp_Year - 2000 -1)/4 +1;
ComY = (Tmp_Year - 2000)-(LeapY);
if (Tmp_Year%4)
//common year
TotDays = LeapY*366 + ComY*365 + Month_Days_Accu_C[Tmp_Month-1] + (Tmp_Date-1);
else
//leap year
TotDays = LeapY*366 + ComY*365 + Month_Days_Accu_L[Tmp_Month-1] + (Tmp_Date-1);
TotSeconds = TotDays*SecsPerDay + (Tmp_HH*3600 + Tmp_MM*60 + Tmp_SS);
#endif
/* Return the value to store in RTC counter register */
//return((Tmp_HH*3600 + Tmp_MM*60 + Tmp_SS));
return TotSeconds;
* Function Name : Time_Adjust
* Description : Adjusts time.
* Input : None
* Output : None
* Return : None
/* Change the current time */
RTC_SetCounter(Time_Regulate());
* Function Name : Time_Display
* Description : Displays the current time.
* Input : - TimeVar: RTC counter value.
* Output : None
* Return : None
#define SecsPerComYear 3153600//(365*3600*24)
#define SecsPerLeapYear 31622400//(366*3600*24)
#define SecsPerFourYear 126230400//((365*3600*24)*3+(366*3600*24))
s32 Year_Secs_Accu[5]={0,
31622400,
63158400,
94694400,
126230400};
s32 Month_Secs_Accu_C[13] = { 0,
2678400,
5097600,
7776000,
10368000,
13046400,
15638400,
18316800,
20995200,
23587200,
26265600,
28857600,
31536000};
s32 Month_Secs_Accu_L[13] = {0,
2678400,
5184000,
7862400,
10454400,
13132800,
15724800,
18403200,
21081600,
23673600,
26352000,
28944000,
31622400};
#if 1
u32 TY = 0, TM = 1, TD = 0;
s32 Num4Y,NumY, OffSec, Off4Y = 0;
u32 i;
s32 NumDay; //OffDay;
#endif
u32 THH = 0, TMM = 0, TSS = 0;
#if 0
/* Compute hours */
THH = TimeVar/3600;
/* Compute minutes */
TMM = (TimeVar % 3600)/60;
/* Compute seconds */
TSS = (TimeVar % 3600)% 60;
#endif
#if 1
Num4Y = TimeVar/SecsPerFourYear;
OffSec = TimeVar%SecsPerFourYear;
i=1;
while(OffSec > Year_Secs_Accu[i++])
Off4Y++;
/* Numer of Complete Year */
NumY = Num4Y*4 + Off4Y;
/* 2000,2001,...~2000+NumY-1 complete year before, so this year is 2000+NumY*/
TY = 2000+NumY;
OffSec = OffSec - Year_Secs_Accu[i-2];
/* Month (TBD with OffSec)*/
i=0;
if(TY%4)
{// common year
while(OffSec > Month_Secs_Accu_C[i++]);
TM = i-1;
OffSec = OffSec - Month_Secs_Accu_C[i-2];
else
{// leap year
while(OffSec > Month_Secs_Accu_L[i++]);
TM = i-1;
OffSec = OffSec - Month_Secs_Accu_L[i-2];
/* Date (TBD with OffSec) */
NumDay = OffSec/SecsPerDay;
OffSec = OffSec%SecsPerDay;
TD = NumDay+1;
/* Compute hours */
THH = OffSec/3600;
TMM = (OffSec % 3600)/60;
TSS = (OffSec % 3600)% 60;
#endif
printf("Date: %0.4d-%0.2d-%0.2d Time: %0.2d:%0.2d:%0.2d\r",TY, TM, TD,THH, TMM, TSS);
* Function Name : Time_Show
* Description : Shows the current time (HH:MM:SS) on the Hyperterminal.
* Input : None
* Output : None
* Return : None
printf("\n\r");
/* Infinite loop */
while (1)
/* If 1s has paased */
if(TimeDisplay == 1)
/* Display current time */
Time_Display(RTC_GetCounter());
TimeDisplay = 0;
* Function Name : USART_Scanf
* Description : Gets numeric values from the hyperterminal.
* Input : None
* Output : None
* Return : None
u32 index = 0;
u32 tmp[4] = {0, 0};
u32 Num;
if (value==2136)
Num = 4;
else
Num = 2;
while(index < Num)
/* Loop until RXNE = 1 */
while(USART_GetFlagStatus(USART2, USART_FLAG_RXNE) == RESET)
tmp[index++] = (USART_ReceiveData(USART2));
if((tmp[index - 1] < 0x30) || (tmp[index - 1] > 0x39))
printf("\n\rPlease enter valid number between 0 and 9");
index--;
/* Calculate the Corresponding value */
if (value!=2136)
index = ((tmp[0] - 0x30) * 10) + (tmp[1] - 0x30);
else
index = ((tmp[0] - 0x30) * 1000) + ((tmp[1] - 0x30) * 100) + ((tmp[2] - 0x30) * 10) + (tmp[3] - 0x30);
/* Checks */
if(index > value)
printf("\n\rPlease enter valid number between 0 and %d", value);
return 0xFF;
return index;
void start_rct(void)
if(BKP_ReadBackupRegister(BKP_DR1) != 0xA5A5)
/* Backup data register value is not correct or not yet programmed (when
the first time the program is executed) */
printf("\r\n\n RTC not yet configured....");
/* RTC Configuration */
printf("\r\n RTC configured....");
/* Adjust time by values entred by the user on the hyperterminal */
Time_Adjust();
BKP_WriteBackupRegister(BKP_DR1, 0xA5A5);
else
/* Check if the Power On Reset flag is set */
if(RCC_GetFlagStatus(RCC_FLAG_PORRST) != RESET)
printf("\r\n\n Power On Reset occurred....");
/* Check if the Pin Reset flag is set */
else if(RCC_GetFlagStatus(RCC_FLAG_PINRST) != RESET)
printf("\r\n\n External Reset occurred....");
printf("\r\n No need to configure RTC....");
/*一下都是可以省略的 RTC_Configuration 已有启用 RTC_IT_SEC */
其中这个函数决定了 printf 函数的输出目标 一定要有的。
int fputc(int ch)
USART_SendData(USART2, (u8) ch);
while(USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET);
return ch;
秒中断;
/* STM32F10x Peripherals Interrupt Handlers */
* @brief This function handles RTC global interrupt request.
* @param None
* @retval None
void LEDToggle(void);
void RTC_IRQHandler(void)
if (RTC_GetITStatus(RTC_IT_SEC) != RESET)
/* Clear the RTC Second interrupt */
RTC_ClearITPendingBit(RTC_IT_SEC);
/* Toggle LED1 闪灯*/
LEDToggle();
/* Enable time update */
TimeDisplay = 1;
不要使用串口助手 推荐使用超级终端。
