单片机 > 单片机程序设计 > 详情
s3c2410_gpio_cfgpin()函数
发布时间:2025-08-28 发布时间:
函数原型:s3c2410_gpio_cfgpin(unsigned int pin,unsigned int function)
位置:/linux-2.6.32.2/arch/arm/plat-s3c24xx/gpio.c
函数内容:
void s3c2410_gpio_cfgpin(unsigned int pin, unsigned int function)
 void __iomem *base = S3C24XX_GPIO_BASE(pin);
 unsigned long mask;
 unsigned long con;
 unsigned long flags;
 if (pin   mask = 1 < }
else {
  mask = 3 << S3C2410_GPIO_OFFSET(pin)*2;
 switch (function) {
 case S3C2410_GPIO_LEAVE:
  mask = 0;
  function = 0;
  break;
 case S3C2410_GPIO_INPUT:
 case S3C2410_GPIO_OUTPUT:
 case S3C2410_GPIO_SFN2:
 case S3C2410_GPIO_SFN3:
  if (pin    function -= 1;
   function &= 1;
   function <<= S3C2410_GPIO_OFFSET(pin);
  } else {
   function &= 3;
   function <<= S3C2410_GPIO_OFFSET(pin)*2;
 /* modify the specified register wwith IRQs off */
 local_irq_save(flags);
 con  = __raw_readl(base + 0x00);
 con &= ~mask;
 con |= function;
 __raw_writel(con, base + 0x00);
 local_irq_restore(flags);
EXPORT_SYMBOL(s3c2410_gpio_cfgpin);
首先确定一下各宏定义所在的位置和意义:
S3C24XX_GPIO_BASE(pin) -->
S3C2410_GPIO_OFFSET(pin)-->
S3C2410_GPIO_INPUT-->
S3C2410_GPIO_OUTPUT-->
S3C2410_GPIO_SFN2-->
S3C2410_GPIO_SFN3-->
以上宏都是在/linux2.6.32.2/arch/arm/mach-s3c2410/include/regs_gpio.h定义.
S3C2410_GPIO_BANKB-->
此宏的定义是在/linux-2.6.32.2/arch/arm/mach-s3c2410/include/mach/gpio-nrs.h中定义.
接下来,顺序解析程序:
#define S3c2410_GPIO_BASE(pin)  ((((pin) & ~31) >>1) + S3C24XX_VA_GPIO)
S3C24XX_VA_GPIO在/linux-2.6.32.2/arch/arm/plat-s3c24xx/include/plat/map.h中是这样定义的:
S3C24XX_PA_GPIO在/linux-2.6.32.2/arch/arm/mach-s3c2410/include/mach/map.h中这样定义:
而S3C2410_PA_GPIO在/linux-2.6.32.2/arch/arm/plat-s3c24xx/include/plat/map.h中这样定义:
S3C24XX_PA_UART在中这样定义:
而S3C2410_PA_UART在/linux-2.6.32.2/arch/arm/plat-s3c24xx/include/plat/map.h中这样定义:
S3C24XX_VA_UART在linux-2.6.32.2/arch/arm/plat-s3c24xx/include/plat/map.h中这样定义:
而S3C_VA_UART在linux-2.6.32.2/arch/arm/plat-s3c/include/plat/map.h中这样定义:
由以上宏定义可以推出:
S3C24XX_VA_GPIO=((S3C24XX_PA_GPIO - S3C24XX_PA_UART) + S3C24XX_VA_UART)
               =((0x56000000 - 0x50000000) + (0xF4000000 + 0x01000000))
               = (0x06000000 + 0xF5000000)
               = (0xFB000000)
这里假设设置GPB5引脚为输出:
s3c2410_gpio_cfgpin(S3C2410_GPB(5),S3C2410_GPB_OUTPUT);
首先S3C2410_GPB(_nr)在/linux-2.6.32.2/arch/arm/mach-s3c2410/include/mach/gpio-nrs.h中这样定义:
关键字:s3c2410  gpio_cfgpin()函数
如何使用AVR-GCC API
