bsp_spi_flash.h
#ifndef __SPI_FLASH_H
#define __SPI_FLASH_H
#include "stm32f4xx.h"
#include
/* Private typedef -----------------------------------------------------------*/
//#define sFLASH_ID 0xEF3015 //W25X16
//#define sFLASH_ID 0xEF4015 //W25Q16
//#define sFLASH_ID 0XEF4017 //W25Q64
#define sFLASH_ID 0XEF4018 //W25Q128
//#define SPI_FLASH_PageSize 4096
#define SPI_FLASH_PageSize 256
#define SPI_FLASH_PerWritePageSize 256
/* Private define ------------------------------------------------------------*/
/*命令定义-开头*******************************/
#define W25X_WriteEnable 0x06
#define W25X_WriteDisable 0x04
#define W25X_ReadStatusReg 0x05
#define W25X_WriteStatusReg 0x01
#define W25X_ReadData 0x03
#define W25X_FastReadData 0x0B
#define W25X_FastReadDual 0x3B
#define W25X_PageProgram 0x02
#define W25X_BlockErase 0xD8
#define W25X_SectorErase 0x20
#define W25X_ChipErase 0xC7
#define W25X_PowerDown 0xB9
#define W25X_ReleasePowerDown 0xAB
#define W25X_DeviceID 0xAB
#define W25X_ManufactDeviceID 0x90
#define W25X_JedecDeviceID 0x9F
#define WIP_Flag 0x01 /* Write In Progress (WIP) flag */
#define Dummy_Byte 0xFF
/*命令定义-结尾*******************************/
/*SPI接口定义-开头****************************/
#define FLASH_SPI SPI5
#define FLASH_SPI_CLK RCC_APB2Periph_SPI5
#define FLASH_SPI_CLK_INIT RCC_APB2PeriphClockCmd
#define FLASH_SPI_SCK_PIN GPIO_Pin_7
#define FLASH_SPI_SCK_GPIO_PORT GPIOF
#define FLASH_SPI_SCK_GPIO_CLK RCC_AHB1Periph_GPIOF
#define FLASH_SPI_SCK_PINSOURCE GPIO_PinSource7
#define FLASH_SPI_SCK_AF GPIO_AF_SPI5
#define FLASH_SPI_MISO_PIN GPIO_Pin_8
#define FLASH_SPI_MISO_GPIO_PORT GPIOF
#define FLASH_SPI_MISO_GPIO_CLK RCC_AHB1Periph_GPIOF
#define FLASH_SPI_MISO_PINSOURCE GPIO_PinSource8
#define FLASH_SPI_MISO_AF GPIO_AF_SPI5
#define FLASH_SPI_MOSI_PIN GPIO_Pin_9
#define FLASH_SPI_MOSI_GPIO_PORT GPIOF
#define FLASH_SPI_MOSI_GPIO_CLK RCC_AHB1Periph_GPIOF
#define FLASH_SPI_MOSI_PINSOURCE GPIO_PinSource9
#define FLASH_SPI_MOSI_AF GPIO_AF_SPI5
#define FLASH_CS_PIN GPIO_Pin_6
#define FLASH_CS_GPIO_PORT GPIOF
#define FLASH_CS_GPIO_CLK RCC_AHB1Periph_GPIOF
#define SPI_FLASH_CS_LOW() {FLASH_CS_GPIO_PORT->BSRRH=FLASH_CS_PIN;}
#define SPI_FLASH_CS_HIGH() {FLASH_CS_GPIO_PORT->BSRRL=FLASH_CS_PIN;}
/*SPI接口定义-结尾****************************/
/*等待超时时间*/
#define SPIT_FLAG_TIMEOUT ((uint32_t)0x1000)
#define SPIT_LONG_TIMEOUT ((uint32_t)(10 * SPIT_FLAG_TIMEOUT))
/*信息输出*/
#define FLASH_DEBUG_ON 1
#define FLASH_INFO(fmt,arg...) printf("<> "fmt"n",##arg)
#define FLASH_ERROR(fmt,arg...) printf("<> "fmt"n",##arg)
#define FLASH_DEBUG(fmt,arg...) do{
if(FLASH_DEBUG_ON)
printf("<> [%d]"fmt"n",__LINE__, ##arg);
}while(0)
void SPI_FLASH_Init(void);
void SPI_FLASH_SectorErase(u32 SectorAddr);
void SPI_FLASH_BulkErase(void);
void SPI_FLASH_PageWrite(u8* pBuffer, u32 WriteAddr, u16 NumByteToWrite);
void SPI_FLASH_BufferWrite(u8* pBuffer, u32 WriteAddr, u16 NumByteToWrite);
void SPI_FLASH_BufferRead(u8* pBuffer, u32 ReadAddr, u16 NumByteToRead);
u32 SPI_FLASH_ReadID(void);
u32 SPI_FLASH_ReadDeviceID(void);
void SPI_FLASH_StartReadSequence(u32 ReadAddr);
void SPI_Flash_PowerDown(void);
void SPI_Flash_WAKEUP(void);
u8 SPI_FLASH_ReadByte(void);
u8 SPI_FLASH_SendByte(u8 byte);
u16 SPI_FLASH_SendHalfWord(u16 HalfWord);
void SPI_FLASH_WriteEnable(void);
void SPI_FLASH_WaitForWriteEnd(void);
#endif /* __SPI_FLASH_H */
bsp_spi_flash.c
#include "./flash/bsp_spi_flash.h"
static __IO uint32_t SPITimeout = SPIT_LONG_TIMEOUT;
static uint16_t SPI_TIMEOUT_UserCallback(uint8_t errorCode);
* @brief SPI_FLASH初始化
SPI_InitTypeDef SPI_InitStructure;
/* 使能FLASH_SPI 及GPIO 时钟 */
/*!< SPI_FLASH_SPI_CS_GPIO, SPI_FLASH_SPI_MOSI_GPIO,
SPI_FLASH_SPI_MISO_GPIO,SPI_FLASH_SPI_SCK_GPIO 时钟使能 */
RCC_AHB1PeriphClockCmd (FLASH_SPI_SCK_GPIO_CLK | FLASH_SPI_MISO_GPIO_CLK|FLASH_SPI_MOSI_GPIO_CLK|FLASH_CS_GPIO_CLK, ENABLE);
/*!< SPI_FLASH_SPI 时钟使能 */
FLASH_SPI_CLK_INIT(FLASH_SPI_CLK, ENABLE);
//设置引脚复用
GPIO_PinAFConfig(FLASH_SPI_SCK_GPIO_PORT,FLASH_SPI_SCK_PINSOURCE,FLASH_SPI_SCK_AF);
GPIO_PinAFConfig(FLASH_SPI_MISO_GPIO_PORT,FLASH_SPI_MISO_PINSOURCE,FLASH_SPI_MISO_AF);
GPIO_PinAFConfig(FLASH_SPI_MOSI_GPIO_PORT,FLASH_SPI_MOSI_PINSOURCE,FLASH_SPI_MOSI_AF);
/*!< 配置 SPI_FLASH_SPI 引脚: SCK */
GPIO_InitStructure.GPIO_Pin = FLASH_SPI_SCK_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(FLASH_SPI_SCK_GPIO_PORT, &GPIO_InitStructure);
/*!< 配置 SPI_FLASH_SPI 引脚: MISO */
GPIO_InitStructure.GPIO_Pin = FLASH_SPI_MISO_PIN;
GPIO_Init(FLASH_SPI_MISO_GPIO_PORT, &GPIO_InitStructure);
/*!< 配置 SPI_FLASH_SPI 引脚: MOSI */
GPIO_InitStructure.GPIO_Pin = FLASH_SPI_MOSI_PIN;
GPIO_Init(FLASH_SPI_MOSI_GPIO_PORT, &GPIO_InitStructure);
/*!< 配置 SPI_FLASH_SPI 引脚: CS */
GPIO_InitStructure.GPIO_Pin = FLASH_CS_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_Init(FLASH_CS_GPIO_PORT, &GPIO_InitStructure);
/* 停止信号 FLASH: CS引脚高电平*/
SPI_FLASH_CS_HIGH();
/* FLASH_SPI 模式配置 */
// FLASH芯片 支持SPI模式0及模式3 据此设置CPOL CPHA
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SP
