//编译环境 AVR Studio 4.17/AVR GCC
//系统时钟7.3728MHZ,设置熔丝位为外部高频石英晶体振荡,启动时间4.1ms
// 包含文件
#include
#include
#define F_CPU 7372800 /* 单片机主频为7.3728MHz,用于延时子程序 */
#include
#include
#include
// 定义变量区
#define uchar unsigned char
#define uint unsigned int
#define delay_us(x) _delay_us(x) //AVR GCC延时函数 x(us)
#define delay_ms(x) _delay_ms(x) //AVR GCC延时函数 x(ms)
#define RS_CLR PORTF &= ~(1 << PF1) //RS置低
#define RS_SET PORTF |= (1 << PF1) //RS置高
#define RW_CLR PORTF &= ~(1 << PF2) //RW置低
#define RW_SET PORTF |= (1 << PF2) //RW置高
#define EN_CLR PORTF &= ~(1 << PF3) //E置低
#define EN_SET PORTF |= (1 << PF3) //E置高
#define Data_IO PORTA //液晶数据口
#define Data_DDR DDRA //数据口方向寄存器
#define D_LE0 PORTD &= ~(1 << PD4) //数码管段控制位为0,锁存端口数据
#define D_LE1 PORTD |= (1 << PD4) //数码管段控制位为1,锁存器输出与端口一致
#define W_LE0 PORTD &= ~(1 << PD5) //数码管位控制位为0
#define W_LE1 PORTD |= (1 << PD5) //数码管位控制位为1
// 初始化子程序
void system_init()
Data_IO = 0xFF; //电平设置
Data_DDR = 0xFF; //方向输出
PORTF = 0xFF; //电平设置
DDRF = 0xFF; //方向输出
PORTD=0xFF;
DDRD=0xFF;
D_LE1; //关掉数码管,以免显示乱码
W_LE1;
Data_IO=0xFF; //关数码管
W_LE0;
// 显示屏命令写入函数
void LCD_write_com(unsigned char com)
RS_CLR;
RW_CLR;
EN_SET;
Data_IO = com;
delay_ms(5);
EN_CLR;
// 显示屏数据写入函数
void LCD_write_data(unsigned char data)
RS_SET;
RW_CLR;
EN_SET;
Data_IO = data;
delay_ms(5);
EN_CLR;
// 显示屏清空显示
void LCD_clear(void)
LCD_write_com(0x01);
delay_ms(5);
// 显示屏字符串写入函数
void LCD_write_str(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
LCD_write_com(0x80 + x);
else
LCD_write_com(0xC0 + x);
while (*s)
LCD_write_data( *s);
s ++;
// 显示屏单字符写入函数
void LCD_write_char(unsigned char x,unsigned char y,unsigned char data)
if (y == 0)
else
LCD_write_data( data);
// 显示屏初始化函数
void LCD_init(void)
DDRA = 0xFF; //I/O口方向设置
DDRA |= (1 << PA5) | (1 << PA6) | (1 << PA7);
LCD_write_com(0x38); //显示模式设置
delay_ms(5);
LCD_write_com(0x08); //显示关闭
delay_ms(5);
LCD_write_com(0x01); //显示清屏
delay_ms(5);
LCD_write_com(0x06); //显示光标移动设置
delay_ms(5);
LCD_write_com(0x0C); //显示开及光标设置
delay_ms(5);
// 主程序
void main(void)
unsigned char i;
unsigned char *p;
system_init(); //系统初始化,设置IO口属性
delay_ms(100); //延时100ms
LCD_init(); //液晶参数初始化设置
while (1)
i = 1;
p = "www.hcit.edu.com"; //字符串输出显示
LCD_clear();
LCD_write_str(0,0,"Welcome");
delay_ms(250);
while (*p) {
LCD_write_char(i,1,*p); //单个字符输出显示
i ++;
p ++;
delay_ms(250); //延时250ms
delay_ms(250);
