嵌入式 > 技术百科 > 详情
ADI血液分析仪解决方案
发布时间:2023-10-08 发布时间:
Blood Analyzer
血液分析信号链由刺激产生仪、数据采集系统及DSP组成。病毒变异进入血液会产生化学反应,并以特定频率修改阻抗值。通过低阻抗探针注射刺激物可获得整个频带的特征,分析响应信号并利用DSP算法计算出与特殊病变对应的有效阻抗值,从而检测出病变类型。
AN-803: Pin Compatible High Speed ADCs Simplify Design Tasks (pdf, 365,050 bytes)
AN-793: ESD/Latch-Up Considerations with iCoupler® Isolation PRODUCTS (pdf, 252,700 bytes)
AN-737: How ADIsimADC™ Models an ADC (pdf, 291,797 bytes)
AN-724: ADUC702X Serial Download Protocol (pdf, 154,552 bytes)
AN-715: A First Approach to IBIS Models: What They Are and How They Are Generated (pdf, 379,082 bytes)
PulSAR® Input Range SOFTWARE
(zip, 13,369,673 bytes)
AN-501: Aperture Uncertainty and ADC SYSTEM Performance (pdf, 233,126 bytes)
A Key Concern in IF Sampling is that of Aperture Uncertainty (Jitter)
AN-138: SPICE-Compatible Op Amp Macro-Models (pdf, 858,957 bytes)
AN-117: OP-42 ADVANCED SPICE Macro-Model (pdf, 172,274 bytes)
AB-3: DIGITAL Nulling of PRECISION Op Amps (pdf, 64,744 bytes)
AN-726: Triple-Supply Power-Good Indication with the ADM108x (pdf, 77,150 bytes)
浅谈IP技术在网络电视中的应用
