采用1602液晶来显示转换结果,端口可以很方便的自己修改的
#include#include #include #define uchar unsigned char #define uint unsigned int #include #define uchar unsigned char #define uint unsigned int uchar vol[3]={000},channel[11]={0x0c,0x1c,0x2c,0x3c,0x4c,0x5c,0x6c,0x7c,0x8c,0x9c,0xac}; /* 端口定义*/ #define LCD_data P0 //数据口 sbit inter_0=P3^2; sbit LCD_RS = P2^7; //寄存器选择输入 sbit LCD_RW = P2^6; //液晶读/写控制 sbit LCD_EN = P2^5; //液晶使能控制 sbit LCD_PSB = P2^4; //串/并方式控制 sbit eoc=P1^0; sbit clock=P1^1; sbit in=P1^2; sbit out=P1^3; sbit cs=P1^4; uint din; void delay(uint x) { uint i,j; for(j=0;j >=4; num=din/4096.0*5.0; num1[0]=(uint)(num)%10+48; num1[1]=46; num1[2]=((uint)(num*10))%10+48; num1[3]=((uint)(num*100))%10+48; lcd_pos(k/3,k%3*3); delay(5); write_dat(num1[0]); delay(5); write_dat(num1[1]); delay(5); write_dat(num1[2]); delay(5); write_dat(num1[3]); delay(5); k++; } } } /*************************************/
