#define GPFCON (*(volatile unsigned*)(0x7F0080A0))
#define GPFDAT (*(volatile unsigned*)(0x7F0080A4))
#define GPFPUD (*(volatile unsigned*)(0x7F0080A8))
#define PCLK 66000000
#define HCLK 133000000
#define TCFG0 (*(volatile unsigned*)(0x7F006000))
#define TCFG1 (*(volatile unsigned*)(0x7F006004))
#define TCON (*(volatile unsigned*)(0x7F006008))
#define TCNTB0 (*(volatile unsigned*)(0x7F00600C))
#define TCMPB0 (*(volatile unsigned*)(0x7F006010))
#define TCNTO0 (*(volatile unsigned*)(0x7F006014))
#define TCNTB1 (*(volatile unsigned*)(0x7F006018))
#define TCMTB1 (*(volatile unsigned*)(0x7F00601C))
#define TCNTO1 (*(volatile unsigned*)(0x7F006020))
#define TCNTB2 (*(volatile unsigned*)(0x7F006024))
#define TCNTO2 (*(volatile unsigned*)(0x7F00602C))
#define TCNTB3 (*(volatile unsigned*)(0x7F006030))
#define TCNTO3 (*(volatile unsigned*)(0x7F006038))
#define TCNTB4 (*(volatile unsigned*)(0x7F00603C))
#define TCNTO4 (*(volatile unsigned*)(0x7F006040))
#define TINT_CSTAT (*(volatile unsigned*)(0x7F006044))
void udelay(unsigned int num)
unsigned int val;
val=PCLK/1000000-1;
TCFG0&=~(0xff<<8);
TCFG0|=(0x00<<8);
TCFG1&=~(0xf<<8);
TCFG1|=(0x0<<8);
TCNTB2=val;
TCON&=~(0xf<<12);
TCON|=(0xb<<12);
TCON&=~(2<<12);
while(num--)
while(TCNTO2>=val>>1);
while(TCNTO2
void init(void)
GPFCON&=~(2<<30);
GPFCON|=(1<<30);
GPFPUD&=~(0x3<
GPFDAT|=(0x8000);
void beep_off(void)
GPFDAT|=0x8000;
void beep_on(void)
GPFDAT&=0x7fff;
void beep(void)
while(1)
int i,j;
beep_on();
for(i=0;i<1000;i++)
udelay(1000);
beep_off();
for(j=0;j<5000;j++)
udelay(1000);
int main()
init();
beep();
int.s
IMPORT main
AREA |C$$code|, CODE, READONLY
global start
start
bl main
END
