STC12C5410AD AD的测试LCD12864显示程序
#include
#include "stdio.h"
#include "stdlib.h"
#include "math.h"
#include "absacc.h"
#include "intrins.h"
#include "string.h"
#define Rssp_On 0x3f
#define Rssp_Off 0x3e
#define Col_Add 0x40
#define Page_Add 0xb8
#define Start_Line 0xc0
sbit Rs = P1^7; //Data or Instrument Select
sbit RW = P1^5; //Write or Read
sbit Ce = P1^6; //6800 mode Enable single
#define Lcd_Bus P2
sbit Cs1 = P1^3; //Master chip enable
sbit Cs2 = P1^4; //Slave chip enable
unsigned char adbuf;
unsigned char code han[]=
/*-- 文字: 值 --*/
/*-- 宋体12; 此字体下对应的点阵为:宽x高=16x16 --*/
0x80,0x40,0xF0,0x2F,0x02,0x04,0xE4,0xA4,0xB4,0xAF,0xA6,0xA4,0xE4,0x04,0x00,0x00,
0x00,0x00,0xFF,0x00,0x40,0x40,0x7F,0x4A,0x4A,0x4A,0x4A,0x4A,0x7F,0x40,0x40,0x00,
/*-- 文字: 电 --*/
0x00,0x00,0xF8,0x48,0x48,0x48,0x48,0xFF,0x48,0x48,0x48,0x48,0xF8,0x00,0x00,0x00,
0x00,0x00,0x0F,0x04,0x04,0x04,0x04,0x3F,0x44,0x44,0x44,0x44,0x4F,0x40,0x70,0x00,
/*-- 文字: 压 --*/
0x00,0x00,0xFE,0x02,0x42,0x42,0x42,0x42,0xFA,0x42,0x42,0x42,0x62,0x42,0x02,0x00,
0x20,0x18,0x27,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x21,0x2E,0x24,0x20,0x20,0x00,
/*-- 文字: 专 --*/
/*-- 宋体-方正超大字符集11; 此字体下对应的点阵为:宽x高=16x16 --*/
0x00,0x00,0x80,0x90,0x90,0xF0,0x9C,0x90,0x90,0x90,0x90,0x88,0x40,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x03,0x02,0x12,0x22,0x72,0x0A,0x06,0x02,0x00,0x00,0x00,0x00,
/*-- 文字: 注 --*/
0x20,0x40,0x84,0xE8,0x20,0x20,0x20,0x22,0x24,0xE8,0x20,0x20,0x20,0x00,0x00,0x00,
0x00,0x38,0x46,0x01,0x00,0x42,0x42,0x42,0x42,0x7F,0x42,0x42,0x42,0x42,0x00,0x00,
/*-- 文字: 于 --*/
0x00,0x80,0x84,0x84,0x84,0x84,0x84,0xFC,0x84,0x84,0x84,0x84,0x84,0x80,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x40,0x40,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*-- 文字: 消 --*/
0x00,0x20,0x40,0x84,0x60,0x00,0xC8,0x30,0x40,0x3E,0x40,0x30,0x48,0xC0,0x00,0x00,
0x00,0x00,0x7C,0x03,0x00,0x00,0x7F,0x09,0x09,0x09,0x09,0x89,0x89,0x7F,0x00,0x00,
/*-- 文字: 费 --*/
0x00,0x00,0xE8,0xA8,0xA8,0xE8,0x9C,0xA8,0xA8,0xFC,0xA8,0xA8,0xB8,0x80,0x00,0x00,
0x00,0x80,0x84,0x9E,0x85,0x44,0x24,0x1C,0x24,0x25,0x24,0x5E,0x42,0x01,0x00,0x00,
/*-- 文字: 类 --*/
0x00,0x20,0x20,0x20,0xA8,0x50,0x20,0xFC,0x20,0x50,0xAC,0xA0,0x20,0x00,0x00,0x00,
0x80,0x82,0x8A,0x49,0x48,0x28,0x19,0x06,0x18,0x28,0x28,0x48,0x49,0x84,0x00,0x00,
/*-- 文字: 控 --*/
0x00,0x20,0x20,0xFC,0x20,0x20,0x30,0x90,0x54,0x1C,0x10,0x50,0xB0,0x10,0x00,0x00,
0x00,0x44,0x82,0x7F,0x01,0x01,0x81,0x84,0x84,0x7C,0x84,0x84,0x84,0x41,0x00,0x00,
/*-- 文字: 制 --*/
0x00,0x60,0x9C,0x90,0x90,0xFC,0x90,0x90,0x50,0x80,0xF8,0x00,0x00,0xFC,0x00,0x00,
0x00,0x00,0x3E,0x02,0x02,0x7F,0x22,0x3E,0x02,0x00,0x0F,0x40,0x40,0x3F,0x00,0x00,
}; [page]
unsigned char code shuzi[]={
/*-- 文字: 0 --*/
/*-- 宋体12; 此字体下对应的点阵为:宽x高=8x16 --*/
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00, //0
/*-- 文字: 1 --*/
0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00, //1
/*-- 文字: 2 --*/
0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00, //2
/*-- 文字: 3 --*/
0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00, //3
/*-- 文字: 4 --*/
0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,
/*-- 文字: 5 --*/
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,
/*-- 文字: 6 --*/
0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,
/*-- 文字: 7 --*/
0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,
/*-- 文字: 8 --*/
0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,
/*-- 文字: 9 --*/
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,
/*-- 文字: a --10*/
0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x19,0x24,0x22,0x22,0x22,0x3F,0x20, //10
/*-- 文字: b --11*/
0x08,0xF8,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x3F,0x11,0x20,0x20,0x11,0x0E,0x00, //11
/*-- 文字: c --12*/
0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x0E,0x11,0x20,0x20,0x20,0x11,0x00, //12
/*-- 文字: d --13*/
0x00,0x00,0x00,0x80,0x80,0x88,0xF8,0x00,0x00,0x0E,0x11,0x20,0x20,0x10,0x3F,0x20, //13
/*-- 文字: e --*/
0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x22,0x22,0x22,0x22,0x13,0x00, //14
/*-- 文字: f --*/
0x00,0x80,0x80,0xF0,0x88,0x88,0x88,0x18,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00, //15
/*-- 文字: g --16*/
0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x6B,0x94,0x94,0x94,0x93,0x60,0x00, //16
/*-- 文字: h --*/
0x08,0xF8,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20, //17
/*-- 文字: i --*/
0x00,0x80,0x98,0x98,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00, //18
/*-- 文字: j --19*/
0x00,0x00,0x00,0x80,0x98,0x98,0x00,0x00,0x00,0xC0,0x80,0x80,0x80,0x7F,0x00,0x00, //19
/*-- 文字: k --*/
0x08,0xF8,0x00,0x00,0x80,0x80,0x80,0x00,0x20,0x3F,0x24,0x02,0x2D,0x30,0x20,0x00, //20
/*-- 文字: l --*/
0x00,0x08,0x08,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00, //21
/*-- 文字: m --22*/
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x20,0x3F,0x20,0x00,0x3F,0x20,0x00,0x3F, //22
/*-- 文字: n --23*/
0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20, //23
/*-- 文字: o --24*/
0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00, //24
/*-- 文字: p --*/
0x80,0x80,0x00,0x80,0x80,0x00,0x00,0x00,0x80,0xFF,0xA1,0x20,0x20,0x11,0x0E,0x00, //25
/*-- 文字: q --*/
0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x0E,0x11,0x20,0x20,0xA0,0xFF,0x80, //26
/*-- 文字: r --*/
0x80,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x20,0x20,0x3F,0x21,0x20,0x00,0x01,0x00, //27
/*-- 文字: s --*/
0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x33,0x24,0x24,0x24,0x24,0x19,0x00, //28
/*-- 文字: t --*/
0x00,0x80,0x80,0xE0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x1F,0x20,0x20,0x00,0x00, //29
/*-- 文字: u --30*/
0x80,0x80,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x1F,0x20,0x20,0x20,0x10,0x3F,0x20, //30
/*-- 文字: v --*/
0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x00,0x01,0x0E,0x30,0x08,0x06,0x01,0x00, //31
/*-- 文字: w --*/
0x80,0x80,0x00,0x80,0x00,0x80,0x80,0x80,0x0F,0x30,0x0C,0x03,0x0C,0x30,0x0F,0x00, //32
/*-- 文字: x --*/
0x00,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x31,0x2E,0x0E,0x31,0x20,0x00, //33
/*-- 文字: y --*/
0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x80,0x81,0x8E,0x70,0x18,0x06,0x01,0x00, //34
/*-- 文字: z --35*/
0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x21,0x30,0x2C,0x22,0x21,0x30,0x00, //35
/*-- 文字: - --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01, //36
/*-- 文字: = --*/
0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00, //37
/*-- 文字: \ --*/
0x00,0x0C,0x30,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x06,0x38,0xC0,0x00, //38
/*-- 文字: --39*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //39
/*-- 文字: [ --*/
0x00,0x00,0x00,0xFE,0x02,0x02,0x02,0x00,0x00,0x00,0x00,0x7F,0x40,0x40,0x40,0x00, //40
/*-- 文字: ] --*/
0x00,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,0x00,0x40,0x40,0x40,0x7F,0x00,0x00,0x00, //41
/*-- 文字: ; --*/
0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x60,0x00,0x00,0x00,0x00, //42
/*-- 文字: ’ --*/
0x10,0x16,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //43
/*-- 文字: , --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xB0,0x70,0x00,0x00,0x00,0x00,0x00, //44
/*-- 文字: . --45*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00, //45
/*-- 文字: / --*/
0x00,0x00,0x00,0x00,0x80,0x60,0x18,0x04,0x00,0x60,0x18,0x06,0x01,0x00,0x00,0x00, //46
/*-- 文字: : --*/
0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00, //47
/*-- 文字: Q --*/
0x07,0x08,0x10,0x10,0x10,0x08,0x07,0x00,0xF0,0x18,0x24,0x24,0x1C,0x0A,0xF2,0x00 //48
//名称: 延时函数
void delay(unsigned int t)
unsigned int i,j;
for(i=0;i
for(j=0;j<10;j++);
//名称: 写一个命令字节到LCD函数
void write_com(unsigned char cmdcode)
Rs=0;
RW=0;
Lcd_Bus=cmdcode;
delay(0);
Ce=1;
delay(0);
Ce=0;
//名称: 写一个数据字节到LCD函数
void write_data(unsigned char Rsspdata)
Rs=1;
RW=0;
Lcd_Bus=Rsspdata;
delay(0);
Ce=1;
delay(0);
Ce=0;
//名称: 清屏函数
void Clr_Scr(void)
unsigned char j,k;
Cs1=1;
Cs2=1;
write_com(Page_Add+0);
write_com(Col_Add+0);
for(k=0;k<8;k++)
write_com(Page_Add+k);
for(j=0;j<64;j++)write_data(0x00);
//名称: 写入地址函数
void werite_x_y(unsigned char x,unsigned char y)
y=y&0x7f;
x=x&0x07;
if(y<64)
Cs1=1;
Cs2=0;
write_com(Col_Add+y);
else
Cs1=0;
Cs2=1;
y&=0x3f;
write_com(Page_Add+x);
} [page]
//名称: 指定位置写16*16汉字函数
void write_chinese(unsigned char x,unsigned char y, unsigned char hz)
unsigned char j=0,i=0;
for(j=0;j<2;j++)
werite_x_y(x+j,y);
for(i=0;i<16;i++) write_data(han[hz*32+16*j+i]);
//名称: 写一个字符到LCD函数(8*16点阵)
//参数:x,y:写入字符的地址 c: 写入字符在shuzi表格中的位置
void write_zifu(unsigned char x,unsigned char y, unsigned char zi)
for(j=0;j<2;j++)
werite_x_y(x+j,y);
for(i=0;i<8;i++) write_data(shuzi[zi*16+8*j+i]); //
//名称: 初始化12864函数
void init_lcd(void)
Cs1=1;
Cs2=1;
delay(250);
write_com(Rssp_Off);
write_com(Start_Line+0);
write_com(Rssp_On);
//名称: 延时约1毫秒函数
void delay1ms()
unsigned int k;
for(k=0;k<12000;k++);
//名称: 模数转换函数(8位)
void adpro()
ADC_DATA = 0; //清A/D转换结果寄存器
adbuf=0;
ADC_CONTR = ADC_CONTR|0x08; //0000,1000ADCS = 1,启动转换
delay1ms();
do{ ; }
while((ADC_CONTR&0x10)==0); //0001,0000等待A/D转换结束
ADC_CONTR = ADC_CONTR&0xE7; //1110,0111清ADC_FLAG位,停止A/D转换
adbuf = ADC_DATA;
//名称: 初始化函数函数
void init()
P1M0=0x01; //设置P1.0为高阻输入,以准备AD
P1M1=0x00;
ADC_CONTR = ADC_CONTR|0x80; //1000,0000打开A/D转换电源
delay1ms();
delay1ms();
ADC_CONTR = ADC_CONTR&0xe0; //1110,0000 清ADC_FLAG,ADC_START位和低3位
//名称: AD值转电压值函数
unsigned int dianya_zhuanhuan()
unsigned int k;
float i_val, f_val;
i_val=(float)adbuf;
i_val=i_val/255;
i_val=i_val*500;
f_val = modf(i_val, &i_val);
if(i_val>999) i_val=999;
k=(int)i_val;
return k;
//名称: 主函数
//作者:huangjianxin
//邮箱:hjx5548@163.com
//日期:2009-12-9
void main()
unsigned int dianyabuf;
init();
init_lcd(); //初始化液晶
Clr_Scr();
while(1)
adpro();
write_zifu(0,0,10); //A
write_zifu(0,8,13); //D
write_chinese(0,16,0); //值
write_zifu(0,32,47); //:
write_zifu(0,40,((adbuf%1000)/100)); //
write_zifu(0,48,((adbuf%100)/10)); //
write_zifu(0,56,(adbuf%10)); //
dianyabuf=dianya_zhuanhuan();
write_chinese(2,0,1); //电
write_chinese(2,16,2); //压
write_zifu(2,32,47); //:
write_zifu(2,40,dianyabuf/100);
write_zifu(2,48,45);
write_zifu(2,56,(dianyabuf%100)/10);
write_zifu(2,64,dianyabuf%10);
write_zifu(2,72,31);
write_chinese(4,0,3); // 专
write_chinese(4,16,4); // 注
write_chinese(4,32,5); // 于
write_chinese(4,48,6); // 消
write_chinese(4,64,7); // 费
write_chinese(4,80,8); // 类
write_chinese(4,96,9); // 控
write_chinese(4,112,10); // 制
write_zifu(6,0,26); //q
write_zifu(6,8,26); //q
write_zifu(6,16,47); //:
write_zifu(6,24,2); //2
write_zifu(6,32,7); //7
write_zifu(6,40,9); //9
write_zifu(6,48,0); //0
write_zifu(6,56,6); //6
write_zifu(6,64,8); //8
write_zifu(6,72,0); //0
write_zifu(6,80,7); //7
write_zifu(6,88,9); //9
