//引入函数库头文件
#include
#include
//用#pragma comment预编译命令,表示这个程序将使用ibcurld_imp.lib这个库文件
#pragma comment(lib,"libcurld_imp.lib")
//复制将数据写入文件的回调函数
size_t write_data(void *ptr, size_t size,size_t nmemb,FILE *stream) {
int written=fwrite(ptr,size,nmemb,stream);
return written;
//使用函数库提供函数实现的文件下载函数
CURLcode download( char* url,
char* out)
CURL *curl = NULL;
FILE *fp = NULL;
CURLcode res;
//调用函数库中的curl_easy _init()函数完成初始化
curl = curl_easy_init();
if (curl)
fp=fopen(out,"wb");
curl_easy_setopt(curl,CURLOPT_URL, url);
curl_easy_setopt(curl,CURLOPT_WRITEFUNCTION, write_data);
curl_easy_setopt(curl,CURLOPT_WRITEDATA, fp);
res=curl_easy_perform(curl);
curl_easy_cleanup(curl);
//下载完成,进行最后的清理工作
fclose(fp);
return res;
else
return CURLE_FAILED_INIT;
//辅助函数,用于获取文件名
void getfilename(char* url, char* name)
char* pos = strrchr(url,"/");
if (NULL!=pos)
strcpy(name,pos+1);
int main(int argc,char* argv[])
if (2!=argc)
puts("usage:get http://www.51hei.com/f/keil3.rar");
return -1;
char* url = argv[1];
char name[32];
getfilename(url,name);
CURLcode res = download(url,name);
if(CURLE_OK==res)
printf("great! download %s as %s succerfully.",url,name);
else
printf("sorry:cannot download %s.",url);
return 0;
