#define uchar unsigned char
#define uint unsigned int
sbit DQ=P1^6;//ds18b20与单片机连接口
sbit RS=P1^0;
sbit RW=P1^1;
sbit EN=P1^2;
sbit BEEP=P1^7;
//unsigned char code str1[]={" "};
unsigned char code str2[]={" "};
uchar data disdata[5];
uint tvalue;//温度值
uchar tflag;//温度正负标志
uchar hshi,hge,Th=25;
uchar Tl=20,lshi,lge;
sbit s1=P2^3; //功能
sbit s2=P2^2; //加
sbit s3=P2^1; //减
sbit gnd=P2^5;
uchar s1num;
/*************************lcd1602程序**************************/
void delay1ms(unsigned int ms)//延时1毫秒(不够精确的)
{unsigned int i,j;
for(i=0;i
void wr_com(unsigned char com)//写指令//
{ delay1ms(1);
RS=0;
RW=0;
EN=0;
P0=com;
delay1ms(1);
EN=1;
delay1ms(1);
EN=0;
void wr_dat(unsigned char dat)//写数据//
{ delay1ms(1);;
RS=1;
RW=0;
EN=0;
P0=dat;
delay1ms(1);
EN=1;
delay1ms(1);
EN=0;
void lcd_init()//初始化设置//
{delay1ms(15);
wr_com(0x38);delay1ms(5);
wr_com(0x80);delay1ms(5);
wr_com(0x01);delay1ms(5);
wr_com(0x06);delay1ms(5);
wr_com(0x0c);delay1ms(5);
void display(unsigned char *p)//显示//
while(*p!='')
wr_dat(*p);
p++;
delay1ms(1);
/*****************报警设置程序******************************/
void wr_Th(uchar add,uchar Th)
wr_com(0x80+add);
hshi=Th/10;
hge=Th%10;
wr_dat(0x30+hshi); //0x30是0的ACSII码,
wr_dat(0x30+hge); //0x30是0的ACSII码,
void wr_Tl(uchar add,uchar Tl)
wr_com(0x80+add);
lshi=Tl/10;
lge=Tl%10;
wr_dat(0x30+lshi); //0x30是0的ACSII码,
wr_dat(0x30+lge); //0x30是0的ACSII码,
void wr_HL()
wr_com(0x80);
wr_dat('H');
wr_com(0x80+9);
wr_dat('L');
init_play()//初始化显示
{ lcd_init();
wr_com(0x80);
wr_Th(4,25);
wr_Tl(12,20);
wr_HL();
wr_com(0xc0);
display(str2);
/******************************ds1820程序***************************************/
void delay_18B20(unsigned int i)//延时1微秒
while(i--);
void ds1820rst()/*ds1820复位*/
{ unsigned char x=0;
DQ = 1; //DQ复位
delay_18B20(4); //延时
DQ = 0; //DQ拉低
delay_18B20(100); //精确延时大于480us
DQ = 1; //拉高
delay_18B20(40);
uchar ds1820rd()/*读数据*/
{ unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
{ DQ = 0; //给脉冲信号
dat>>=1;
DQ = 1; //给脉冲信号
if(DQ)
dat|=0x80;
delay_18B20(10);
return(dat);
void ds1820wr(uchar wdata)/*写数据*/
{unsigned char i=0;
for (i=8; i>0; i--)
{ DQ = 0;
DQ = wdata&0x01;
delay_18B20(10);
DQ = 1;
wdata>>=1;
read_temp()/*读取温度值并转换*/
{uchar a,b;
ds1820rst();
ds1820wr(0xcc);//*跳过读序列号*/
ds1820wr(0x44);//*启动温度转换*/
ds1820rst();
ds1820wr(0xbe);//*读取温度*/
a=ds1820rd();
b=ds1820rd();
tvalue=b;
tvalue<<=8;
tvalue=tvalue|a;
if(tvalue<0x0fff)
tflag=0;
else
{tvalue=~tvalue+1;
tflag=1;
tvalue=tvalue*(0.625);//温度值扩大10倍,精确到1位小数
return(tvalue);
}[page]
void ds1820disp()//温度值显示
{ uchar flagdat;
disdata[0]=tvalue/1000+0x30;//百位数
disdata[1]=tvalue%1000/100+0x30;//十位数
disdata[2]=tvalue%100/10+0x30;//个位数
disdata[3]=tvalue%10+0x30;//小数位
if(tflag==0)
flagdat=0x20;//正温度不显示符号
else
flagdat=0x2d;//负温度显示负号:-
if(disdata[0]==0x30)
{disdata[0]=0x20;//如果百位为0,不显示
if(disdata[1]==0x30)
{disdata[1]=0x20;//如果百位为0,十位为0也不显示
wr_com(0xc0);
wr_dat(flagdat);//显示符号位
wr_com(0xc1);
wr_dat(disdata[0]);//显示百位
wr_com(0xc2);
wr_dat(disdata[1]);//显示十位
wr_com(0xc3);
wr_dat(disdata[2]);//显示个位
wr_com(0xc4);
wr_dat(0x2e);//显示小数点
wr_com(0xc5);
wr_dat(disdata[3]);//显示小数位
wr_com(0x80+0x40+7);
wr_dat(0xdf); //写入摄氏度的小圈
wr_com(0x80+0x40+8);//写入摄氏度的C
wr_dat('C');
/*功能按键扫描函数*/
void keyscan()//按键扫描函数 ,如果有按键按下,按照按下的功能键执行相应功能
if(s1==0)
delay1ms(5);
if(s1==0)
s1num++;
while(!s1);//松手检测
if(s1num==1) //
wr_com(0x80+13);
wr_com(0x0f);//光标开始闪
if(s1num==2)//被按两下,
wr_com(0x80+5);
if(s1num==3)//被按三下
s1num=0;
wr_com(0x0c);//开显示,光标不显示
if(s1num!=0)
if(s2==0)
delay1ms(5);
while(!s2);
if(s1num==1)
Tl++;
wr_Tl(12,Tl);//
wr_com(0x80+13);//因为每次写入指
针自动加一,所以将批针前移一位
if(s1num==2)
Th++;
wr_Th(4,Th);
wr_com(0x80+5);
if(s3==0)
delay1ms(5);
while(!s3);
if(s1num==1)
Tl--;
wr_Tl(12,Tl);
wr_com(0x80+13);
if(s1num==2)
Th--;
wr_Th(4,Th);
wr_com(0x80+5);
void exter0()interrupt 0
BEEP=1;
keyscan();
/********************主程序***********************************/
void main()
gnd=0;
init_play();//初始化显示
EA=1;//开总中断
EX0=1;//开外中部断0
IT0=0;//设定中断触发方式。IT0=0是电平触发方式。IT0=1是下降沿触发方式。12脚当中断源
while(1)
read_temp();//读取温度
ds1820disp();//显示
if((tvalue/10)>=Th||(tvalue/10)<=Tl)
delay1ms(2000);
//BEEP=0;
else
BEEP=1;
