sbit DIO=P1^2; sbit CLK=P1^1; sbit STB=P1^0; #define DIG0 0xc0 #define DIG1 0xc2 #define DIG2 0xc4 #define DIG3 0xc6 #define DIG4 0xc8 #define DIG5 0xca #define DIG6 0xcc #define DIG7 0xce #define LEVEL_OFF 0x80 #define LEVEL_1 0x88 #define LEVEL_2 0x89 #define LEVEL_4 0x8a #define LEVEL_10 0x8b #define LEVEL_11 0x8c #define LEVEL_12 0x8d #define LEVEL_13 0x8e #define LEVEL_14 0x8f #define MD_WRITE 0x40 #define MD_AUTO MD_WRITE #define MD_NORMAL MD_WRITE #define MD_READKEY 0x42 #define MD_FIX 0x44 #define MD_TEST 0x48 typedef unsigned char uint8; typedef unsigned int uint16; uint16 key; code uint8 shuzu[17] ={ 0x3F,0x06,0x5B,0x4F, 0x66,0x6D,0x7D,0x07, 0x7F,0x6F,0x77,0x7c, 0x39,0x5e,0x79,0x71, 0x00, }; void xianshi(uint8 x,uint8 led,uint8 level); void shizhong(); void chushi(); void ClearAll(); void KeyRead(uint16 *key); void indate(unsigned char input) { unsigned int i; STB=0; for(i=0;i<8;i++) { CLK=0; if((input & 0x01)!=0) DIO=1; else DIO=0; CLK=1; input=input>>1; } } unsigned char outdate() { unsigned char i,out=0; DIO= 1; STB=0; for(i=0;i<8;i++) { CLK=0; out=out>>1; if(DIO == 0) out=out & 0x7f; else out=out | 0x80; CLK=1; } return(out); } void chushi() { CLK = 1; STB = 1; DIO = 1; } void jishi() { TMOD |= 0x10; TMOD &= 0xdf; TH1=0xb8; TL1=0x00; TR1=1; EA=1; ET1 = 1; } void ql() { xianshi(7,0,LEVEL_11); xianshi(6,0,LEVEL_11); xianshi(4,0,LEVEL_11); xianshi(3,0,LEVEL_11); xianshi(1,0,LEVEL_11); xianshi(0,0,LEVEL_11); } void xianshi(uint8 x,uint8 led,uint8 level) { uint8 i; static uint8 cled[8]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,}; for(i = 0 ;i < 8;i ++ ){ if((shuzu[led]>>i)&0x01) cled[i] |= (0x01<< x); else cled[i] &= ~(0x01<< x); } DIO=1; CLK=1; STB=1; indate(MD_WRITE); STB = 1; indate(DIG0); for( i = 0 ; i<16; i+= 2){ indate(cled[i/2] & 0x0f); indate(cled[i/2] >> 4 & 0x0f); } STB=1; indate(level); STB=1; } void ClearAll() { unsigned int i; DIO=1; CLK=1; STB=1; indate(MD_AUTO); STB=1; indate(DIG0); for(i=0;i<16;i++) indate(0); STB=1; indate(0x80); STB=1; } void KeyRead(uint16 *key) { unsigned char key1,key2; STB=1; indate(MD_READKEY); key1 = outdate(); key2 = outdate(); *key = key1 | (key2 << 8); STB=1; } void delay() { uint16 n; uint8 k; for(k=0;k<10;k++) { for(n=0;n<6000;n++) ; } } [page] void zhongduan()interrupt 3 { shizhong(); } void shizhong() { static uint16 count=0; static uint16 scount=0; static uint8 a=0; static uint8 b=0; static uint8 c=0; static uint8 d=0; static uint8 x=0; static uint8 y=0; TH1=0xb8; TL1=0x00; count++; if(count==5) { count=0; scount++; x=scount/10%10; y=scount/100%10; xianshi(7,x,LEVEL_11); if(scount%600==0) { xianshi(6,0,LEVEL_11);scount=0;a++; } else xianshi(6,y,LEVEL_11); if(a>=10) { a=0;b++; } xianshi(4,a,LEVEL_11); if(b>=6) { b=0;c++; } xianshi(3,b,LEVEL_11); if(d<2){ if(c==10){ c=0;d++;} xianshi(1,c,LEVEL_11); xianshi(0,d,LEVEL_11);} else if(d>=2){if(d>2)d=0; if(c==4){ c=0;d=0;} xianshi(1,c,LEVEL_11); xianshi(0,d,LEVEL_11);} KeyRead(&key); if(key==0x0008)a++; KeyRead(&key); if(key==0x0080)b++; KeyRead(&key); if(key==0x0800)c++; KeyRead(&key); if(key==0x8000)d++; if(key==0x0004){scount=0; x=0;y=0;} }} main() { ql(); jishi(); while(1){};
