常见AD电阻网络连接方式一般为下图连接方式,对于不同的应用,可能电阻有所调整,如何使用宏定义实现ADC值自动计算?
Z 10K
Z
1200 1000 820 680 560 470 |
-----WW------WW-----WW-------WW------WW------WW------------ >ADC
\K0 \K1 \K2 \K3 \K4 \K5 \K6
为代码便于调整,现定义宏,设定每个电阻值:
//ADC 电路采样参数
#define RES_POL 10 //上拉电阻,单位K
#define ADC_MAX 1024 //ADC采样精度
//AD键盘各个电阻值,单位是K
#define RES0 0.01
#define RES1 0.47
#define RES2 0.56
#define RES3 0.68
#define RES4 0.82
#define RES5 1.00
#define RES6 1.20
#define RES7 1.50
#define RES8 1.80
#define RES9 2.20
#define RES10 2.70
#define RES11 3.30
#define RES12 4.70
#define RES13 6.80
#define RES14 10.0
#define RES15 18.0
#define RES16 33.0
#define RES17 82.0
然后计算每个开关电阻累加和
#define RES_SUM0 (RES0)
#define RES_SUM1 (RES_SUM0+RES1)
#define RES_SUM2 (RES_SUM1+RES2)
#define RES_SUM3 (RES_SUM2+RES3)
#define RES_SUM4 (RES_SUM3+RES4)
#define RES_SUM5 (RES_SUM4+RES5)
#define RES_SUM6 (RES_SUM5+RES6)
#define RES_SUM7 (RES_SUM6+RES7)
#define RES_SUM8 (RES_SUM7+RES8)
#define RES_SUM9 (RES_SUM8+RES9)
#define RES_SUM10 (RES_SUM9+RES10)
#define RES_SUM11 (RES_SUM10+RES11)
#define RES_SUM12 (RES_SUM11+RES12)
#define RES_SUM13 (RES_SUM12+RES13)
#define RES_SUM14 (RES_SUM13+RES14)
#define RES_SUM15 (RES_SUM14+RES15)
#define RES_SUM16 (RES_SUM15+RES16)
#define RES_SUM17 (RES_SUM16+RES17)
再通过预编译运算出实际的ADC值
#define KEY_ADC0 (RES_SUM0/(RES_SUM0+RES_POL)*ADC_MAX)
#define KEY_ADC1 (RES_SUM1/(RES_SUM1+RES_POL)*ADC_MAX)
#define KEY_ADC2 (RES_SUM2/(RES_SUM2+RES_POL)*ADC_MAX)
#define KEY_ADC3 (RES_SUM3/(RES_SUM3+RES_POL)*ADC_MAX)
#define KEY_ADC4 (RES_SUM4/(RES_SUM4+RES_POL)*ADC_MAX)
#define KEY_ADC5 (RES_SUM5/(RES_SUM5+RES_POL)*ADC_MAX)
#define KEY_ADC6 (RES_SUM6/(RES_SUM6+RES_POL)*ADC_MAX)
#define KEY_ADC7 (RES_SUM7/(RES_SUM7+RES_POL)*ADC_MAX)
#define KEY_ADC8 (RES_SUM8/(RES_SUM8+RES_POL)*ADC_MAX)
#define KEY_ADC9 (RES_SUM9/(RES_SUM9+RES_POL)*ADC_MAX)
#define KEY_ADC10 (RES_SUM10/(RES_SUM10+RES_POL)*ADC_MAX)
#define KEY_ADC11 (RES_SUM11/(RES_SUM11+RES_POL)*ADC_MAX)
#define KEY_ADC12 (RES_SUM12/(RES_SUM12+RES_POL)*ADC_MAX)
#define KEY_ADC13 (RES_SUM13/(RES_SUM13+RES_POL)*ADC_MAX)
#define KEY_ADC14 (RES_SUM14/(RES_SUM14+RES_POL)*ADC_MAX)
#define KEY_ADC15 (RES_SUM15/(RES_SUM15+RES_POL)*ADC_MAX)
#define KEY_ADC16 (RES_SUM16/(RES_SUM16+RES_POL)*ADC_MAX)
#define KEY_ADC17 (RES_SUM17/(RES_SUM17+RES_POL)*ADC_MAX)
这样,在ADC采样运用中可设计如下数组:
UINT16 keyAdcTable1[] = {
KEY_ADC0,
KEY_ADC1,
KEY_ADC2,
KEY_ADC3,
KEY_ADC4,
KEY_ADC5,
KEY_ADC7,
KEY_ADC8,
KEY_ADC9,
KEY_ADC10,
KEY_ADC11,
KEY_ADC12,
KEY_ADC17,
通过查表法可方便的获得当前某个按键是否按下。
此法在运算上没有特别之处,只是巧妙利用C的预编译处理,美化代码,同时简洁了操作步骤,常规的固定值计算方法如果某个电阻发生变化,需要调整后续一系列ADC计算值,非常不方便,如有更巧妙算法,欢迎讨论!
